Misc. Disc Brake problem
I just picked up a 76 CJ5 that came with some kind of bad attempt to put disc brakes on the front and I am not sure what is the correct approach to take.
I have seen vids of people doing the disc brakes kits, etc..., but I do not really want to spend $700 to fix this problem if I don't have to.
The CJ came with studs welded in the rotor and the weld job was insanely crappy and I assume they just ended up warping the rotors.
Does the Dana 30 secure the hub to the spindle first then the rotor? Or the studs are in the rotor and then the hub?
Any help with this would be greatly appreciated as it has baffled quite a few parts supply places and 4x4 shops.
