death
Okay everyone, I have a 1999 xj. I’m working on putting a 4.5'' suspension lift under it. It is my daily driver so a little at a time and when budget allows. I am doing the "Budget lift" I have put springs out of the front of an old F150 and I have air shocks in the back for now. So its not driving up hill to bad. I will be putting rear leaf packs from a Dakota and a SYE kit in ( its on order ) I do have a cv style drive shaft that was the front drive shaft from another 99 xj
That I will be using after the SYE kit is in. Now here is the problem. When I am traveling at 45mph or more, even the slightest little bump in the road will cause the jeep to shake violently! It jars your bones it is so bad... WOW. I have a snow plow that I will be using this winter that is what started the whole thing, but when I had the plow on after all this to date I didn’t have the problem as bad. I have taken the plow of for gas mileage and cooling and no snow.
I should also point out that I jacked up the front of the jeep, when I grab the tire I feel no play in anything, I also have no slop in the steering wheel. The shaking feels like it is from the driver side... Thanks for any help!
