Dana 300 rear output shaft end play
simple man
I have finally gotten around to rebuilding my Dana 300 and have run into a problem regarding setting the end play on the rear output shaft. After assembling the shaft and getting an initial end play reading, .005, I added a .003 shim and remeasured the end play and got a .005 reading. So I added another shim and there was no change in the end play reading.
My assumption is that the the inaccuracies in the end play measurements are caused by user error in setting the dial gauge. In setting up and resetting the gauge I may be getting inaccurate readings. In setting the gauge I am trying to place the gauge against the end of the threaded portion of the shaft. However, one questions is could the torquing the yoke on and removing it and replacing it be affecting the output shaft. For example, could I somehow be stretching the shaft?
Is there any trick in setting up the dial gauge?
Another strange problem I have had when installing the yoke is that the yoke will only fit on the shaft in one specific orientation. If the yoke is placed five splines left or right it will not slide all the way onto the shaft. I have tried the yoke on the input shaft and it doesn't have a problem. Any idea of what may be causing this, could the shaft be damaged? Could this be related to the above problem?
