TCase Dana 300 Poppet ball and spring
Transfer case
miked
niagara
78 cj5 5.7, twin stick D30 front,D44 rear. 80 cj7 renegade 304,D30,D20, Dana 300,auto trans.
On stock 1980 dana 300 tc are both the front and rear shift rail poppet ball and springs the same? I got new springs and poppet balls but im not sure they are correct. The rear rail spring bore is deeper than the front. Does that need a longer spring. I been searching a lot and cant find any definative answers. Any help would be appreciated. Thank you in advance!
They're the same
You running a twin stick or no?
No, the dana 300 came with a 80 CJ7 with an automatic transmission.
Thought maybe you were doing a swap
Reason I asked is there's an issue with the ball and spring involving the case jumping out of gear on occasion when run with a twin stick
Yes, Ive heard thats a problem with the twin stick. The 78 CJ5 I picked up this summer has a twin stick. Havnt had it out wheeling much to experience it happening.
Do you know if both pills are supposed to slide back and forth between both shif5 rail bores? 1 of the pills will slide from one bore to the other. The other pill slides full into 1 bore and slides a 1/4 the way into the other bore.
Novak has springs that will help out with that. I installed them in my dana 300 haven't had any issue. Im running a twin stick
Same here. Used the Novak kit on my Dana300 and have had no issues at all in 4 years.
That was where I was headed with the question...JB has one, too
I have a Novack twin stick on my 300 and never had any trouble popping out of gear. Around 14k miles on the whole set up now. :jeepgrin:
I twin sticked mine years ago and bought everything JB made for D300 no issues poping out of gear either
