Dana 300 End Play and springs
Ultrunner
I have two questions for the experts here. Installing my transfer case rear bearing cap, I started with the original number of shims (3) and then put on the cap, end bearing and yoke and toqued the retaining bolts to spec. The shaft was tight to turn, but not impossible, but there was no play. I took everything off and went through it all again two more times, I’m up to 5 shims. The shaft turns slightly easier but still no end play. What am I doing wrong?
Also, how the hell do you get the second spring out (and subsequently the new one back in) of the front bearing cap, where the shifter forks go through? The front one drops right out along with the ball, when you remove it since there is a hole. The other one doesn’t have a bottom hole and I cannot get it out to replace it. Spring is all rusty.
