Clutch Linkage: Release rod and adjuster problems
Jslampe
If you’ve been following at home, I had a couple problems with my clutch linkage (driver side pivot bracket sheared off the bolts). Upon review of the linkage, bell crank, etc., it looked pretty rough so I ordered a whole new kit for $70. (Before you ask, no I didn’t get the Heim upgrade. Will eventually. Need several other parts in the original kit.)
http://repairguide.autozone.com/zne...00c152/80/04/b2/23/large/0900c1528004b223.gif
The problem I’m having now, is with the Release Rod/Adjuster and/or the Throwout Lever. Even at their shortest setting, the Release Rod + Adjuster are far too long. When I placed them in the the Throwout bracket, the RR+Adj was a solid 1 inch too long creating a healthy gap between the Inner Support Bracket and the transmission casing (where the bolts go).
Illustrations to (maybe help):
https://drive.google.com/drive/folders/1Z4zEVPMv9WVXfwSJgPLxt7pn5nb47lhf?usp=sharing
The most confusing part is comparing the old Release Rod and Adjuster withe new one… They’re the EXACT same size as the new one! WTF am I doing wrong?
Furthermore, Throwout Lever won’t move by hand like I’d assumed it would’ve. I know the Transmission is fine-ish. When the linkage broke I was able to jimmy-rig a fix with a piece of wood and drive it up the driveway into the garage.
I feel like an idiot, but there’s got to be something I’m missing. I’M SO CLOSE
