CJ5 1973 Gas Tank Repair
dabbrowne
- Pleasanton Ca
- 1973 CJ5 (AMC 1976 360 5.9L rebuilt) V8 Edelbrock Weber 1406 4 barrel carb with TorqueFlite 727 Auto transmission, 31" tires, Dana 30 Front Diff, Dana 44 Back , Dana 20 T case.
Hello Any advice on where to get a sending unit for my gas tank? Also it looks like PO took off the carbon filter and the roll over check valve. Also PO connected one of the vent tubes back to the top of the gas filter by the carb and the other vent tube goes to the Liq check valve. Then connected the other to connections on he Liq check valve.
It seems to run fine.
