Automatic CJ Transmissions
BusaDave9
Always Off-Roading Jeeper
- Durango, Crawlarado
- 1979 Jeep CJ5 with 304 V8, T18 Transmission, Dana 20 Transfer case with TeraLow 3:1 gears, 4.88 axle gears, Detroit Locker up front and Ox Locker in back with 1 piece axle shafts, 36" SuperSwamper SX Tires, Shackle reversal, MileMarker Hydraulic winch, MSD 6A ignition.
TH400
Three Speed Automatic
The GM Turbo Hydramatic 400 has the reputation of one of the best automatic transmissions ever made. This strong 3 speed automatic can easily handle a high horsepower engine. The only issue with the TH400 is it's relatively tall gearing. There are kits to lower the gearing but they are expensive. The TH400 is also a long transmission at 24.37 inches.
The TH400 was the first automatic transmission to come in a CJ. It was available from 1976 to 1979. It only came in CJs that were equipped with the QuadraTrac 1339.
Gear Ratios
1st – 2.48
2nd – 1.48
3rd – 1.00
Reverse – 2.07
Gear Ratios
1st – 2.48
2nd – 1.48
3rd – 1.00
Reverse – 2.07
