Diff AMC 20 Fill Plug
Differentials
CCKCJ785
Efland, NC
1985 CJ7, 4.2L 258
Any help or ideas to remove this fill plug will be appreciated. Does anyone know the proper Allen head size? Can't drain it till I can fill it. Just got the CJAMC 20 Fill Plug.jpg
i believe it's a torques bit. but for that one id weld a nut to it and use a 6 point socket to remove it
Sent from my E6810 using Tapatalk
The one on mine was a 1/2 inch square recessed hole and I just used a 1/2in breaker bar and some heat to loosen it up. I ended up replacing it with a plug that has a 1/2 in square head that I can get a wrench on
3/8 ". I keep a string tied to that one so I don't have to guess each time
Not sure how to PM you sorry. Glad to have it but not necessary hate to see it go to waste. Thank you
In xenforo pm's are called 'conversations'. Just hover over the user name and you can start one.
Won't be a waste if you can use it...has a good threaded Allen head plug
if he doesnt want it i can use it
$210.00
