amc 20 axle to bearing play excessive
ozusa
Has anyone found an outer axle bearing that was loose in the axle housing?
I have that problem with the bearing race is loose in the axle housing.
Bearing race is 2.55" outside diameter and the axle hole opening is 2.60".
So the bearing race is .05 loose in the axle house.
Certainly can't install and drive like that.
Anyone seen before or ideas on who has tolerance shims installs for the issue?
The bearing is a timken with the 2 piece axle assembly.
Thanks,
Thanks,
