Aftermarket Crown gauges SUUUUUUCK! HELP!!!!
rumblephish
- Central California
- 1978 Jeep CJ-5 "Levi's" edition, original AMC 304 V8, T-150 transmission, Dana 20 transfer case, AMC 20 rear end. All stock except for a hotter ignition.
I purchased a complete set of replacement gauges (Crown Speedo cluster, voltmeter and oil pressure) to replace the worn out non-working original gauges.
I have come to the conclusion that Crown gauges SUCK!
I am now on my second set of temp/fuel and oil pressure gauges. The first mistake was my own. I got clumsy and touched a hot lead to the grounding post of the oil gauge and POOF! there it went. It also took out the regulator in the fuel gauge and thus burned up my temp gauge. Yes, I'm an idiot.. I know.
So on my second set now and nothing works! I replaced the gauge cluster fuse now FIVE times! I've followed the gauge testing procedure and trouble shooting and I think the regulator in the fuel gauge is bad I get 12v reading on the temp gauge A post. I'm so frustrated that I'm about to dose this thing with 91 octane and throw a lit match at it!!
Every time I put a fresh fuse in and turn the key to "on" the gauge fuse instantly blows. What gives?? I'm thinking of just buying an all new Painless wiring harness and aftermarket gauges. This thing is turning into a f**king money pit! ARRRRRRRRRGGGGGHHHHHHHHHHHHH!!!!!
