A ride for a trailer queen
IOPort51
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
I have been thinking about buying a 14' tandem axle trailer to tow the CJ on.
The days of me driving the CJ more than 200 miles are gone, just too old and soft , I guess. I also take the CJ to some places that offer the real possibility of it needing to be carried home. What ever the reason I have tried flat towing and although it works I can't help but think a trailer would be more stable and having brakes back there would be a real plus.
The situation with the tow vehicle is the deciding factor. A Toyota Tacoma with 2.7 4 cylinder is just fine for down on the flat in Texas but on those special occasions that I get to go to the mountains it proves to be a little week at high altitudes. I am Ok with this and don't think I am going to trade the Toyota in any time soon. All things considered The thought of adding 16 or 17 hundred pounds to the load is a bit of a concern.
The questions are: will the reduction of rolling resistance from wide high profile gnarly treaded off road tires to slightly over inflated street treaded trailer tires be significant?? Will the additional width and lower over all center of gravity of the trailer make the load a bit more civilized at highway speed?? Would I be as well off with a two wheeled tow dolly with electric brakes and a whole lot less weight and a wider wheel track, at least in the front?? In the event of a problem limiting the use of a jeep axle I would think it would ride as well forward as backwards. For that matter if the jeep was loaded on the dolly backwards it would eliminate the need to drop the rear drive shaft.
I can't say that I have a lot of experience pulling a trailer so if you do, please feel free to jump in with your .02 .
