84'Cj-7 Cranks, but will not start
Casey j
I'm having an issue with my 84 CJ7 not starting. Jeep will crank over but will not fire. The other day when I shut it off the piece in my steering column that connects to the bar / ignition broke and now I have no fire from distributor. I started at coil tested red and green wire which both have power. Solenoid has power and ignition control module has power at red and white wire and at white wire. Also I checked purple and orange wire on bottom of distributor and it is reading 425 ohm.
