'76 CJ-5 Rear diff/axle/hub questions
- VA
- '76 CJ5, 351w, Ford T18/D20, D44 (open), D30 (open), 2.5" BDS spring lift, 31x10.5x15 tires
Posting kind of in conjunction with my post here regarding some nasty drum brake squeak that I have:
http://www.jeep-cj.com/forums/f49/cyclical-drum-brake-squeak-another-brake-problem-29956/
I'm thinking worse case scenario...I might have a bad bearing and would have to replace it.
So my questions...
I have a '76 CJ5. It's been restored, and I didn't restore it...don't know the PO either. There's a lot of stuff on it that's not original. Was born with a 258, but has a 304 in it now with a T-18 and Dana 20 xfer case. The front diff is a Dana 30, and the rear is a Dana 44. Did '76s come with a Dana 44? I thought the AMC20 was for that year...maybe it was an option, I don't know. I can get pictures eventually, but it's definitely a Dana 44 back there. Just trying to see if what I have is not original to the Jeep.
Next question...did the Dana 44 come with 2-piece axles? If so, and if the bearing is toast, I think I'm just going to overhaul and replace with 1-piece.
I've never messed with replacing axles before, but I'm assuming I can learn whatever I need with a quick youtube search, correct?
Appreciate any answers on this.
The reason why I'm asking is because I drove the Jeep around one more time in the neighborhood to help me try to figure out exactly what was wrong before I go tearing into it, and when I got over 30mph or so, and the whole drive train started getting wobbly on me...seemed to be resonating from the rear axle. Could be that the rear brake was causing it because I have issues in there, or bearings are shot...but there was no real noise other than the cyclical squeaking of that rear left brake. It was even wobbling my transmission because the shifter was wobbling back and forth to match the frequency of the squeak.
I'm hoping it's just the brake that failed and not something else...but I want to be prepared for the worst.
Thanks all.
So my questions...
Thanks all.
