1986 late year Dana 44 Question
RattleTrap
- Northern, VA
- '84, CJ7, 258, T5, D300, AMC20, D30
Hesco MFI & Howard Cam on 33 w/4" lift
I have a 1984 CJ7 that I am in the process of rebuilding & modifying. This is my first post on this site - however I made good use of the site while rebuilding the CJ. I know, you are really never finished rebuilding/modifying a Jeep......
My question -
I recently purchased a Dana 44 rear axle from a 1986 late year CJ7 – all the measurements and marking check out. The axle is complete except for the brake consumables (pad, springs, wheel cylinder). So far so good – everything I have been able to find, including the Jeep parts list, clearly states that the brake backing plate, wheel cylinder, shoes, and drum are different and NOT usable on the AMC20 and vise versa.
I have measured the brake backing plate & drums on both the AMC20 and the Dana 44 only to find that they are the same in every way. What am I missing? Does anyone have information/specs for the brakes for the 1986 mid-year CJ7 Dana 44? Also does anyone know if it is possible retro fit the backing plate from an AMC20 to the Dana 44? If so, that is like what happened to this axle explaining the drum and backing plate.
The part number for the Dana 44 backing plate is 83502984 (R) & 83502985 (L)
The part number for the AMC20 backing plate is J4488452 (R) & J4488453 (L)
The only markings I can find are on the right backing plate which reads either 4F-5017R or 4F-5317B, wear & time has taken its toll on the stamping. Regardless these numbers do not match anything I can find.
I am stuck until I figure this out as I do not know what parts to order for the rebuild/build. I realize that the brakes are the last thing I need, so I am not too stressed, yet.
Thank you for your help.
Garner
My question -
Garner
