Build Thread 1977 CJ7 Rebuild and Conversion
Hello everybody!
I am in the process of acquiring a 1977 CJ7 from a coworker. It's in need of a lot of love, but it should make for a sweet project. It's essentially a frame and a body. I drained 5 quarts of water out of the engine, it has no transfer case or driveshafts, and the automatic transmission that came with it is pretty rusted. On the bright side, it appears to have a lift, 33" tires, and roll cage (rather than just the bar). The frame and body are in pretty good shape considering that the vehicle sat through a massive flood.
My current plans for the build are as follows:
- Chevy Vortec V8
- SM465
- NP205
- Capable of moderate off-road trails in the Boulder area
- Seating for 3
- Disc Brakes
I currently have little idea if the stock axles are salvageable, so that should be a significant portion of the project, along with the interior. The interior has been stripped, so I get to start from square one on that.
It's an ambitious project, but it should be a blast! I'm fortunate to have access to a mill, lathe, drill press, and welder. I also have a good friend in welding school, so I should be able to fabricate a lot of things myself. For a lot of it though, I will have to make the decision between building something myself and just buying the part. I do tend to value my money a lot more than my time though, so we'll see what I actually buy.
So far, I haven't been too good at taking pictures, but I will try to do better on this front in the future! I'm looking forward to sharing the process with you all!
- Chevy Vortec V8
- SM465
- NP205
- Seating for 3
- Disc Brakes
