Electrical Upgrade/Adjust Fuel Sending Unit
TSB8C
Old Time Jeeper
Featured
13
Cut-n-Shoot, TX
1984 CJ7, 420 HP "ZZ6 EFI" Crate engine, 700R4, D300, Dana30 front, Dana489 rear, 4.56 gears, 4" lift
Your fuel pump is four years old. Replace it.
These pumps are rated for well over 75K miles, depending on fuel quality and whether you keep it submerged in fuel (stay above 1/4 tank or so) or whether it's allowed to run more often while not submerged. Gas acts as a coolant for the pump if it remains submerged in fuel most of the time. So running your tank low frequently can reduce the lifespan. My tank was also new 4 years ago, so no real dirt/debris to worry about either. I have about 25K miles over the past 4 years since it was installed. I certainly expect another 30K - 40K miles before any issue with the pump itself. And with the access panel in the floor, easy enough to replace when the time comes. This job of replacing the float took all of about 1 hour, including the meter readings and adjustments made.
Good call on the brass float and sending unit access. I'm gonna order a float for when that comes. I did send unit access on the first two jeeps we built. I used the Holley external pump, simply because it would be easy to change if needed. Guess what? It was needed one day on the side of the road in blistering heat. Glad I had a backup and tools needed.
I hate those plastic ones, always fail, good catch
what's a good external pump to use for a carburetor, do you still need a pressure regulator?
You looking for an electric pump for carb use, or a mechanical engine-driven pump? I prefer Holley pumps. They make a number of options for carb use in the $50 - $100 range, depending on your GPH need. Pressure wise, about 4-7 psi is needed for most carbs. No separate regulator needed. They do also have mechanical engine-driven pumps, but I think those are overrated for most people's needs. Holley's #12-427 is a great electric choice for carb use at a good price and can be used for all gas types (different grades, ethanol blends, additives, etc).
If I remember correctly, I used the Holley 2225. I'll verify that before lunch tomorrow. No regulator.
