Default Welder upgrade question
Old 09-23-2016, 06:10 PM   #11
gert is online now
X2 on what hdgapeach said, Miller, Lincoln, and esab are all good welders the Lincoln 180 will do you good for years to come.
The Following User Says Thank You to gert For This Useful Post:
Hedgehog (09-23-2016)
Default Re: Welder upgrade question
Old 09-23-2016, 08:03 PM   #12
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
Guys - I am well aware of the following Miller has with professional welders. Fact is I said it a couple times right here in this thread. No question about their quality and you can count Hobart right there among the rest. The 180 is sitting right here in my shop. I dropped by a welding supply shop today and bought a bottle of 75/25 gas. After switching the leads and loading the welder up with wire the first test beads were run on scrap material. I am officially impressed. The puddle is far easier to see and control. About the only thing I didn't like and I'm sure its easy enough to get accustomed to, is the size of the gas shroud. I'm having a little trouble seeing around it.
Now I want to remove the roll cage/bar/metal thing on my jeep and redo all the welds making them pretty.
Learned a valuable thing today. The little gas bottles you get from H-F are empty. Why sell them at all since you would turn the nice new bottle in to get a full one. Nowhere on the bottle or in their add does it say that the bottle is empty. I felt extremely foolish, but H-F took it back without any hassle.
Old 09-23-2016, 08:07 PM   #13
gert is online now
I cannot tell you how pissed off I was when I spent all that money to buy a brand new bottle from tractor supply to turn around and give it away to get a full bottle I usually pull the bead and angle the tip so I can see where I'm welding because that shroud does get in the way
Old 09-23-2016, 08:09 PM   #14
Lumpy Grits is online now
All of those type bottles are shipped empty to avoid HAZ-MAT charges and the permit fees for storage. IF the store could even get the permits.
Good luck with the welder? Post up some pictures if you can.
Old 09-23-2016, 09:47 PM   #15
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
Not surprised, but they should somehow make it clear that the bottles are empty. Also those little guys aren't much of a good deal. They are $100, the much bigger bottle I got cost less than $150 full of gas. Refills are about $37 .... really you turn in the bottle for a full one.
pictures? Sure, you've seen it before .... Red .... two dials on the front .... bottle in the back. Or are you talking bout a picture of the weld bead? Oh my, you know how showing about any weld bead will bring out the welding wolves with no end to the kindly given advice about how to improve the bead is.
Old 09-24-2016, 03:09 AM   #16
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
Something to get used to. After getting accustomed to using 0.30 or 0.35 flux core wire in the 140 I am amazed at how much more power you need with 0.25 gas shielded wire. Where the flux core used an "A" setting the smaller wire needs a "C" with the feed way up there to get the penetration I expect. It definitely is a case where the puddle is easier to manage, but its not as hot. I've also yet to find that nice bacon cooking crackle, it's more like a controlled short. ...... a learning curve.
Old 09-24-2016, 09:12 AM   #17
Posi is offline
Posi
Posi's Avatar
Just the other day you said you never get invited to any neighborhood BBQ........I can understand why.
Talking Re: Welder upgrade question
Old 09-24-2016, 09:31 AM   #18
Picture of the weld, was what I should have said.
Hedgehog (09-24-2016)
Old 09-24-2016, 03:56 PM   #19
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
Thanks Posi - You are a little late, I actually expected something like that from you on the thread you quoted. Yeah I'm not a popular personality, my face has been rubbed in it many times so feel free to pile on, you aren't alone.
Lumpy - Before weld pictures I need to work with this welder for a while. I wrote what I did because I've seen it over and over again on the welding sites. No matter what someone who isn't a "Certified" welder shows a weld, the professionals pile on ... to hot ... to cold ... to fast ... and the best one, "all your welds are crap and you shouldn't be showing them on a welding site." That last one was someone trying to show how various welding rods produce a weld. The guy was trying to help and he got endless grief for it. I absolutely know my welds are crap, but I'm trying and my welds are far better than they once were. My father was a certified welder so I know what a good weld looks like.
The Following User Says Thank You to Hedgehog For This Useful Post:
Lumpy Grits (09-24-2016)
Old 09-25-2016, 10:46 AM   #20
I bought a Klutch 140 from Northern tool. All the features at 1/2 the price.
FREE SHIPPING Klutch MIG 140SI Flux-Core/MIG Welder 115V, 140 Amp, Inverter-Powered | MIG Flux Core Welders| Northern Tool + Equipment
I have been very impressed with it. If I still welded for a living I would have given more thought to name brands but for something that is "just for fun" I would stack it up with any bodies 115/140 amp machine. It will even carry a spool gun if I want.
I find the 2# spools are a PITA and the c-25 tank is way too small but it is actually rather hard to make a ugly weld. Of course I would not use it for anything heavier than 10 ga. I also have a Miller 225 HF that will GTAW and SMAW for any thing heavier.
All that said, I think you made an excellent choice and had a great bit of luck to find one used for a good price.
I would suggest to anyone reading this that it is an excellent habit to use a wiper pad on the wire before it enters the feed rollers/wire conduit, in my experience the most common problems occur when the inside of the conduit become restricted with dust carried in with the wire and even though these machines do a good job or enclosing the wire and feed rollers , for the cost of a piece of tack rag and a spring clip it is good insurance.
question , upgrade , welder
Dash Light Upgrade Question CDT540 Chassis and Body 3 10-31-2012 10:52 AM
Team Rush upgrade question sarfu Chassis and Body 3 06-02-2012 05:37 PM
On-Board Welder/Alternator Welder? mhubacek Shops, Equipment and Tools 23 05-19-2011 08:52 AM
AMC 304 ignition upgrade question brian613 Drivetrain 8 03-29-2010 01:13 PM
TFI upgrade question CJ777 Drivetrain 32 02-23-2010 10:08 PM
