Default Re: My antique engine
Old 09-23-2017, 05:10 PM   #11
hole is offline
hole
hole's Avatar
Images: 28
Rep Power: 12 hole is on a distinguished road
Never knew the catsup trick, good info!
Old 09-30-2017, 08:35 AM   #12
shum8 is online now
shum8
Voted most irritating
shum8's Avatar
Images: 2
Originally Posted by Posi View Post
[/SIZE][/FONT][/SIZE][/FONT]
Now hold up a second...... ketchup did THAT? I need to leave the house more often.... Removes grease? Rust? What all does it work on?
Old 09-30-2017, 08:49 AM   #13
HackFabrication is offline
HackFabrication
Vehicle(s): 1976 CJ5 2017 Grand Cherokee Summit
Rep Power: 11 HackFabrication is on a distinguished road
Heinz Catsup. Naval Jelly, before there was Naval Jelly....
Old 09-30-2017, 09:04 AM   #14
shum8 is online now
shum8
shum8's Avatar
Images: 2
Outstanding - I love learning stuff like this.....
Old 09-30-2017, 09:53 AM   #15
Posi is offline
Posi
Posi's Avatar
Ketchup, tomato paste is acetic and will clean brass. In my case the carb was very dirty so first I put it in my parts cleaner to remove the engine oil and dirt. I then spread ketchup on all the brass parts and let it sit for an hour. It cleaned the brass, but not as good as you see in the last pic. I then used tomato paste and let it sit for an hour. After an hour I use some steel wool then soap and water to where you see it in the last pic. I found the tomato paste worked better then the ketchup maybe because the ketchup was watered down a bit.
Again, the carb was heavily tarnished any lightly tarnished household brass should clean up fairly well with one application.
Besides what Hack mentioned, lemon juice with a bit of salt or baking soda (used as an abrasive) or white vinegar work good as well.
Rust on chrome, coke and aluminum foil work great at cleaning rusted chrome.
http://www.jeep-cj.com/forums/f73/be...e-pepsi-26548/
oldjeeplady (09-30-2017)
Old 09-30-2017, 11:29 AM   #16
Rep Power: 14 mtnwhlr is on a distinguished road
I have always used SOS pads and water.
Old 11-27-2017, 12:28 PM   #17
Posi is offline
Posi
Posi's Avatar
After rebuilding the Schebler carb I went through the engine and cart as well. I also built an engine cradle.
1921 Ottawa 3.5HP
The Following 5 Users Say Thank You to Posi For This Useful Post:
007 (11-27-2017), Bill D (11-28-2017), Lumpy Grits (11-29-2017), oldjeeplady (11-27-2017), shooby (11-28-2017)
Old 11-27-2017, 02:34 PM   #18
Posi is offline
Posi
Posi's Avatar
Finished my McCormick Deering 3HP engine as well.
https://youtu.be/eQMzrwPFhjk
The Following 3 Users Say Thank You to Posi For This Useful Post:
Old 06-12-2018, 02:25 PM   #19
JeffP is offline
JeffP
Vehicle(s): '75 CJ5, 304, T18, D20, D44s w/3.73 1974 CJ5, 304, 4 spd., Dana axles 3.73 gears. 1973 CJ5, 258 I6, T18, Dana 20, Dana axles 4.27 gears. 1972 CJ5, 304, 4 Spd, Dana 20, 4.27 gears. 1976 CJ5, 304, T150. 1976 CJ5, 304, T150, J20 w/4.10 gears. 69 CJ5 Hurricane 4 cyl, 4spd all original! Ď53/Ď54 M38a1 100% original but also 100% apart! Low 3 digit Vin! One of the very first m38a1s!
JeffP's Avatar
Images: 27
Rep Power: 3 JeffP is on a distinguished road
Anyone else interested in old engines?
Last week I picked up a McCormick-Deering 2.5 HP engine. I haven't pin down the build year yet but figure around 1923-27
The engine hasn't run in several years so I drained and cleaned the fuel tank, went through the electrical system which consist of an ignition magneto, spark plug wire, and spark plug. I greased the bearings and oiled the cylinder, all oiling is done manually. The engine is all cast iron and weighs around 500lbs.
A video of the first starting attempt. Enjoy!
https://www.youtube.com/watch?v=RyfMSTfhZKI
I just wet my pants! That was the bestvideo Iíve seen in a very long time!
Old 06-12-2018, 04:34 PM   #20
Posi is offline
Posi
Posi's Avatar
Good to hear you enjoyed it.
I finished my Ottawa but haven't had time to do the first startup.
I'll take a video when that time comes.
I also had a 1925 Novo but I sold it before I took a video of it running. However, the buyer did send me a video.
20160423_130557.mp4
JeffP (06-12-2018)
antique , engine
engine swap? From 4.2l I6 to 4.3l v6? Problems, costs, best chevy engine years? 76cj7chick Drivetrain 11 05-29-2013 10:01 PM
How to buy an engine thistle3585 Drivetrain 6 05-22-2013 04:49 PM
'77 DJ-5 Engine Run-On Westward Chassis and Body 0 07-31-2012 01:22 AM
V8 Engine BusaDave9 Drivetrains 0 01-22-2012 10:49 PM
Antique Jeep Identification Needed Allen9878 Chassis and Body 4 03-13-2011 02:07 PM
