Default Cleaning Steel?
Old 11-11-2016, 01:29 AM   #1
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
This is a relevant question for most anybody working with new rolled steel. There must be an easier way to clean the coating off raw rolled steel than using a flap wheel to clean it off for a quality weld. Most any advice would be appreciated.
Default Re: Cleaning Steel?
Old 11-11-2016, 12:41 PM   #2
Lumpy Grits is online now
Is this the 'scale' rust coating or?
Old 11-12-2016, 10:01 AM   #3
HackFabrication is offline
HackFabrication
Vehicle(s): 1976 CJ5 2017 Grand Cherokee Summit
Rep Power: 11 HackFabrication is on a distinguished road
I'm going to assume he's talking about mill scale that would be present on hot rolled steel. Most cold rolled steel will only have surface rust or trace lube from processing.
If it's hot rolled steel, and depending on the size of the piece, I either run it through the sandblast cabinet, or get the angle grinder out.
"In the end...It's all Hack."
Old 11-12-2016, 01:46 PM   #4
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
Yes it's the hot rolled steel scale. I was hoping there would be some sort of chemical method for removal. This stuff even resists cleaning with an angle grinders flap wheel. It can be done but it's tedious and now that the job is done darned near impossible to do. I've more or less completed an 8274 Winch plate (highly modified H-F plate), now for the finishing. Maybe I'll send it to the powder coater. They will sand blast it before coating, but it's pricey process.
Old 11-12-2016, 01:56 PM   #5
HackFabrication
Muriatic acid will strip it. But it's a nasty and somewhat dangerous process. I'm done a number of small pieces with it, but the larger ones are a different story.
Best to get it blasted. I use a medium grit aluminum oxide in my cabinet.
Old 11-12-2016, 02:17 PM   #6
Do you have a 'jitter-bug' type sander like what is used in body work?
I have had good luck with them in removing that dang scale for welding etc.
Old 11-12-2016, 02:33 PM   #7
Muriatic will turn it white but not remove it. I fail to see the problem, are you making bad welds? Hot rolled is what hot rolled is.
Old 11-12-2016, 05:06 PM   #8
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
On various shows they mention that the slag has to be removed for clean welds, especially for MIG welding where things need to be clean. The edges are easy enough to clean before welding. It's the over all flat area's that are no fun. Then there can be issues in painting. It's also bad for a forging process like forge or hammer welding. A while ago there was a show called "Big Giant Swords". In one of the episodes he used some sort of a process where he made a shallow container, laid his metal in it and added a chemical (not acid, it could have been vinegar) that over time lifted or loosened the slag to be wire brushed off. Unfortunately I can not remember what he used.
I recently gave my sand blaster to a friend. It was given to m and I ran out of room to store it in the garage. There is a company that sand blasted my roll bar so I think I'll be using them. Part of the advantage of sand blasting is to clean tight areas for I can't get to.
Old 11-13-2016, 11:47 PM   #9
there is a difference between slag and mill scale. SMAW stick welds and flux cored wire should be brushed between passes for best results to remove slag. I use a brush on a 4" grinder. GSMA Welds with gas shielded hard wire will be more affected by oil or paint, anything that contaminated the gas shield and air movement that blows the shield away, Do not try to mig weld in front of a fan.
Forge welding is a completely different proposition and it is a rather slim chance you will have need of it.
My powder coater blasts everything before paint and the rino coat would need something in the 30 grit flex disk range
I hope this is of some help to you.
Old 11-14-2016, 12:48 PM   #10
Hedgehog is offline
Hedgehog
Hedgehog's Avatar
All information is helpfull. Forge welding, I've been thinking about building a forge. Blacksmithing has always fascinated me. So, the question on removing scale is multi faceted.
A wire wheel on my grinder is a must. Unfortunately I can't always get into the tight spaces, even with a hand held brush. No fans in my work area.
cleaning , steel
Cleaning your Best Top Hedgehog Chassis and Body 6 01-08-2014 09:52 PM
cleaning the frame polish85 Chassis and Body 12 03-24-2013 12:59 PM
cleaning the motor JeePHeaD Misc CJ Discussion 4 12-06-2010 06:49 PM
Metal Cleaning kj 7 Shops, Equipment and Tools 13 12-18-2009 07:38 PM
FRAME Cleaning BrockGrimes Chassis and Body 19 05-09-2009 09:38 AM
