Default Post trailer builds or finished trailers here!!!
Old 01-28-2015, 06:51 PM   #1
Im looking to turn a tub I have into a trailer to tow more camping gear. Theres a few threads on here but Id love to see everyones trailer ideas. I listed some links below for those interested. T.I.A.
http://www.jeep-cj.com/forums/f72/trailer-build-17778/
http://www.jeep-cj.com/forums/f72/my...trailer-19865/
http://www.jeep-cj.com/forums/f72/le...-trailers-842/
http://www.jeep-cj.com/forums/f72/trailer-project-2691/
Default Re: Post trailer builds or finished trailers here!!!
Old 03-07-2015, 06:10 PM   #2
Peanut Butter is offline
Peanut Butter
Peanut Butter's Avatar
Images: 37
Here is another link to a very good trailer build but on another site: Bolt-together fiberglass Jeep-tub trailer kit - JeepForum.com
My neighbor when I lived in Colorado built my trailer. I Paid $300 for it. This last year I decided to spruce it up a bit so that it would match my Jeep CJ7.
Before:
During:
AFTER:
Tub is 4 foot wide and 6 feet long. Plan is to build a slide in camper for it. That way I can use one trailer for either camping or hauling cargo. The tub is made of galvanized metal. I used a ceramic urethane paint that is tough as nails and will be the same color as the Jeep. I changed all the lights to LEDs and added some reflective stickers. Pulls really nice. Has a set of Subaru Brat Wheels on it. Tires are on only 13 inch wheels, but has lots of ground clearance. I updated the hitch to a 2" ball and will be adding a jack. Had to drill two holes in the tube as it would hold rain water. Over all I'm very pleased with my little trailer.
The Following User Says Thank You to Peanut Butter For This Useful Post:
Petescj (03-09-2015)
Old 03-07-2015, 06:55 PM   #3
coldair is offline
coldair
coldair's Avatar
Images: 44
Read my mind Pete
Old 03-09-2015, 09:05 AM   #4
Thanks Rod. I'm Familiar with Jeffs work. Always good stuff. I'm debating wether to grab the Cj8 project I'm looking at or sink it into tools for the garage. I could turn my Limited tub into a trailer pretty easy if I learn to weld.
Old 03-10-2015, 03:29 PM   #5
Peanut Butter
Images: 37
Here are some addition links for small camping trailers:
Tiny Trailer Forum:Teardrops n Tiny Travel Trailers • Index page
Moby Campers:Moby1 Expedition Trailers LLC
Trekker Trailers:Trekker Trailers
Signatour Campers: SignaTour Campers
Runaway Campers: RunawayCampers.com - Home
I really like the Runaway for the price, but I only have room for one trailer at the new house, so it will be something I can slide in and out, but similar to the Runaway.
Old 06-11-2018, 04:55 PM   #6
JeffP is offline
JeffP
Vehicle(s): '75 CJ5, 304, T18, D20, D44s w/3.73 1974 CJ5, 304, 4 spd., Dana axles 3.73 gears. 1973 CJ5, 258 I6, T18, Dana 20, Dana axles 4.27 gears. 1972 CJ5, 304, 4 Spd, Dana 20, 4.27 gears. 1976 CJ5, 304, T150. 1976 CJ5, 304, T150, J20 w/4.10 gears. 69 CJ5 Hurricane 4 cyl, 4spd all original! ‘53/‘54 M38a1 100% original but also 100% apart! Low 3 digit Vin! One of the very first m38a1s!
JeffP's Avatar
Images: 27
Rep Power: 3 JeffP is on a distinguished road
Built from scratch... copy of military trailer but with 4’ x 6’ floor. 8’ with tailgate down. Dual hitches... pintle hook or 2” ball coupler. 5x5.5” lug pattern on 3500lb axle.
21419981-aecd-4731-b6d9-0f58eff0f3ea.jpg   d06caee5-00c1-4403-9775-fd952bf75773.jpg   bd479211-6012-4db9-8ba8-90c248073fb2.jpg   c8a721cc-e4c0-4bdc-9c2a-046c33d86e7f.jpg   bfeb6e73-2ca0-4b44-ac7d-497903db70f6.jpg
Old 06-11-2018, 05:05 PM   #7
JeffP is offline
JeffP
JeffP's Avatar
Images: 27
One thing I always wondered about... Why do people bother with much more expensive off-road tires on trailers when traction isn’t an issue?
Standard trailer tires have tougher / stiffer sidewalls to prevent sway or sagging when fully loaded. Why spend more for reduced performance?
Old 06-12-2018, 09:10 AM   #8
I would run the same size tire/wheel on my trailer, that is on the jeep.
Part of the KISS deal.
Larger dia tires ride the rocks better than a smaller OD one will.
Old 06-12-2018, 06:13 PM   #9
JeffP is offline
JeffP
JeffP's Avatar
Images: 27
The tire height and ground clearance is the same for the Jeep that will pull it offroad, the only difference is the width, tread and tire design. The spare will interchange anywhere.
If I happen to use it with another Jeep on the street, tire size won’t matter.
Besides, it’s not the only trailer we built. We spent almost a month building three of them. The colors have to match the tow vehicle! lol
builds , finished , post , trailer , trailers
Let's talk trailers II csuengr Outdoor Related 3 03-03-2013 11:42 AM
off road trailers, Holy cow! IOPort51 Outdoor Related 16 01-07-2013 07:02 AM
Finished the spray liner finally. firefyter Chassis and Body 3 09-15-2011 08:38 AM
Finished my SBC conversion brn371 Drivetrain 4 11-13-2010 12:59 PM
Just finished a pretty cool job. coldwater Sand, Dirt and Mud 3 11-21-2009 06:44 PM
