Default Jeep Trailer(s)
Old 01-10-2018, 12:43 AM   #1
JeffP is offline
JeffP
Vehicle(s): '75 CJ5, 304, T18, D20, D44s w/3.73 1974 CJ5, 304, 4 spd., Dana axles 3.73 gears. 1973 CJ5, 258 I6, T18, Dana 20, Dana axles 4.27 gears. 1972 CJ5, 304, 4 Spd, Dana 20, 4.27 gears. 1976 CJ5, 304, T150. 1976 CJ5, 304, T150, J20 w/4.10 gears. 69 CJ5 Hurricane 4 cyl, 4spd all original! 53/54 M38a1 100% original but also 100% apart! Low 3 digit Vin! One of the very first m38a1s!
JeffP's Avatar
Images: 27
Rep Power: 3 JeffP is on a distinguished road
A few months ago I finally found & bought an M416 trailer. My joy was short lived when I discovered the interior dimensions were not 4x6 feet as I always believed.
The primary purpose for this trailer was camping / off road adventures but also to use it as a utility trailer allowing me to haul an occasisonal sheet of plywood etc..
After learning the size discrepency I decided to build one. I copied the design of the military trailer but used 16 ga steel for the body & 1/8 thick tube for the frame. The tongue is 1/4 2x3 channel.
Both welded & aircraft rivets. The bed, front wall & inside tailgate are 1/8 diamond plate.
The bed inside is 48 1/2 wide by 72 1/2 long. With the tailgate down, it is just over 8 long. Perfect for hauling anything I want!
The M416 weighs 602lbs and mine weighs in at exactly 700lbs. Not bad considering how much stronger it is.
The top-rails are 1x1x 1/8 square tube because I didnt have any way to form the round edge.
The tongue has a 2 receiver tube with accommodates either a 2 ball coupler or a lunette ring for a pintle hook.
Axle is rated at 3500lbs, hubs at 5,000lbs with a 5 on 5.5 bolt pattern to match my Jeeps. The hitch is 5,000 and 15,000 lb capacity.
All the lighting is LED.
Im extremely pleased with the way it turned out & may go into production making more. Next time Ill try square fenders.
7e5a3920-a2f7-4296-80be-ab0449afae8f.jpg   ebc977fe-4455-4512-ba7c-9c136b4ff018.jpg   4f8a82d1-715c-4388-829c-b4ae7d381f86.jpg   c3e0f2cc-1b97-4e95-a74b-ea33c52d2fe8.jpg   7e71475d-687b-48e7-a3ba-09c740e25d22.jpg
The Following 2 Users Say Thank You to JeffP For This Useful Post:
HackFabrication (01-10-2018), shum8 (01-10-2018)
Default Re: Jeep Trailer(s)
Old 07-14-2018, 11:20 PM   #2
Dan77CJ7 is offline
Dan77CJ7
Vehicle(s): 76' CJ-7 4.2L/T-18/d20 d30sua/amc20soa M/T MTZp3 35/12.50/15s mc2100
Dan77CJ7's Avatar
Rep Power: 6 Dan77CJ7 is on a distinguished road
Nice trailer Jeff,
Im working on a expedition trailer build, still working on the rack so I can mount my roof top tent but shes got pressurized water, 2000w inverter/20amp solor charger and a 200ah battery.
Iv nevery pulled a trailer off-road but my torsion axle really make it capable! Pulled her all over Ouray with little hassles.
e725d585-da6d-4186-9e30-a8ef0b2b48ef.jpg   8ca46fe6-a668-46cb-962a-7a2c4c30d45e.jpg   70fa0a06-8680-4245-bf06-63f243eb7041.jpg   16c444e9-1602-4a0e-8ea6-f909dd265ef5.jpg   76a63a8f-d7d9-4b86-b5c7-82fb8100c5f5.jpg
The Following 2 Users Say Thank You to Dan77CJ7 For This Useful Post:
Idahododgeram (07-28-2018), Lumpy Grits (07-15-2018)
Old 07-14-2018, 11:49 PM   #3
Belizean is online now
Belizean
Belizean's Avatar
Both those trailer are real nice looking !
Dan77CJ7 (07-15-2018)
Old 07-15-2018, 12:11 AM   #4
Dan77CJ7 is offline
Dan77CJ7
Dan77CJ7's Avatar
thanks! Here a couple more shots.
I wanted an m416 to start with but I found this one and is only weighs 430lbs I wanted to keep the weight lower then a 1000lbs loaded weight but Im always lookin for m416 fixer for around town hauling plus my cj seem to be acting up some, maybe she needs a lil friend too 🤪
32d26b43-c309-47e7-8efd-28f5a01b4cc2.jpg   8047c1c5-716b-4821-9dbd-7fb4331d96b6.jpg   0a17b73f-f484-4b93-a632-c942a64f0bd1.jpg   23914065-09f7-46ee-92dc-801189413a86.jpg
Old 07-15-2018, 12:16 AM   #5
Belizean
Belizean's Avatar
Real easy to get to your stuff with those top openings like that
Old 07-15-2018, 12:27 AM   #6
Dan77CJ7 is offline
Dan77CJ7
Dan77CJ7's Avatar
Once I get the rack welded the rooftop unit has a annex room that has a zippered opening that will allow access to the passenger side of the trailer its going to be nice waking up and walking down a ladder and plugging in the coffee maker and still be in my skibbys 😂 and not offend the wildlife..
Old 07-15-2018, 04:09 PM   #7
Belizean
Belizean's Avatar
I look forward to seeing pictures of the whole thing set up. I've see a couple of them on the newer jeeps with that set up and one on a trailer
Old 07-26-2018, 07:16 PM   #8
Dan77CJ7 is offline
Dan77CJ7
Dan77CJ7's Avatar
Finally got the rack together and mounted and the table set up.
Tomorrow I get my RTT!!
df26fd61-790d-4e10-bb60-2f2a877bb432.jpg   54c8aa52-6a35-4980-945a-0dd1763caaed.jpg   eb87a216-f0c7-45f9-9558-1aba0e1d6c33.jpg
The Following User Says Thank You to Dan77CJ7 For This Useful Post:
Old 07-30-2018, 04:49 PM   #9
Dan77CJ7 is offline
Dan77CJ7
Dan77CJ7's Avatar
Shes just about finished, solar panels are next!
9513d437-a444-443e-8509-d385aa84e38e.jpg   d5f1d640-7ce7-4749-8dda-12edd2952f90.jpg   a5219df0-62ba-4052-ab07-2a06ca47d420.jpg   fb97ccb6-0346-4dd6-9efe-1747660c5062.jpg
Lumpy Grits (07-30-2018), Super8mm (07-30-2018)
Old 08-01-2018, 07:17 PM   #10
Belizean
Belizean's Avatar
Looking good
Dan77CJ7 (08-02-2018)
jeep , trailers
Building a Jeep Trailer Kit Im Not Spam Jeep News and RSS feeds. 0 11-14-2017 05:30 PM
83 Jeep CJ7 and 1967 Army Trailer hologenicman Members CJs 5 07-04-2014 03:27 PM
Jeep and car trailer - $800 (Dunlap Tn) priceg Great Deals! 1 07-19-2012 02:53 PM
How to fit 26' of Jeep on a 20' trailer. . . Catharps Misc CJ Discussion 4 02-26-2012 11:17 PM
M100 1/4 ton Jeep trailer LASTCJ786 Jeeps other than CJ's 25 12-28-2010 01:22 AM
