Default Wiring issue with wipers...maybe
Old 10-18-2019, 05:51 PM   #1
CJ7JEEP1979 is offline
CJ7JEEP1979
Vehicle(s): 1979 CJ7 304 bored .30 over with a performance cam. 4 speed manual, 35x12.50x15 tires, 4 inch suspension lift. 4 barrel Holley.
CJ7JEEP1979's Avatar
Rep Power: 0 CJ7JEEP1979 is on a distinguished road
I have a 1979 CJ7 with a 304 and 4 speed manual. The wiper motor is a 3 wire. The original switch was missing and all that was left hanging under the dash was the switch portion that the wires plug into. I bought a new switch , plugged it in and nothing happens. I removed the dash pad and looked at the motor and traced the 3 wires back and they are intact. How does the wiper motor actually get power? I have not removed it but all I see are the 3 wires coming out of it that plug into the switch. Obviously it is never going to have power as Those 3 wires only communicate to the switch. I have looked at the wiring diagram and it only shows those three wires and I know motors do not run on magic. Could someone explain what other wire(s) should be present because I have a feeling this thing is missing a wire somewhere. Also the new switch has 5 prongs on it and the plug from the motor only uses three of them. Thank you for any help you can provide.
Default Re: Wiring issue with wipers...maybe
Old 10-18-2019, 06:41 PM   #2
JeeperChris is offline
JeeperChris
JeeperChris's Avatar
Rep Power: 1 JeeperChris is on a distinguished road
I think the switch is grounded by mounting on the dash plate. Is it in the dash or hanging?
And I'll check my wiring diagram too.
Old 10-18-2019, 06:49 PM   #3
JeeperChris
Ok, it's the motor being mounted that provides the ground and all I see are the same three wires - black, red, green, and I have no idea where the power comes from either.
Old 10-19-2019, 12:09 AM   #4
GRR is offline
GRR
Vehicle(s): 1980 CJ7, 258, T176, D300
GRR's Avatar
Rep Power: 0 GRR is on a distinguished road
3 wires to the motor, 1 wire supplies power to the switch, and one wire to the windshield washer
Old 10-19-2019, 12:41 AM   #5
GRR is offline
GRR
GRR's Avatar
This one shows the wires from the wiper motor
Old 10-21-2019, 01:49 PM   #6
CJ7JEEP1979
Thank you to everyone! Definitely a lifesaver! I need to replace the linkage in the windshield and I am going to go ahead and get a new motor in case this one does not work. I would rather have a spare on hand then not have one if needed.
issue , wipers...maybe , wiring
Wiring issue jakeh937 Body, Electrical, Chassis 9 06-02-2018 07:16 PM
Wiring issue - won't start explosion242 Chassis and Body 31 11-22-2016 05:48 PM
Alternator, Battery, or wiring issue? SGT Chassis and Body 48 06-08-2015 07:23 PM
Wipers mikemrq Chassis and Body 3 12-30-2012 12:58 PM
wipers shepherd1 Misc CJ Discussion 6 06-04-2010 12:05 PM
