Default windshield wiper fix
Old 02-08-2011, 08:21 PM   #1
Cheepjeep85 is offline
Cheepjeep85
Cheepjeep85's Avatar
Rep Power: 13 Cheepjeep85 is on a distinguished road
well the inevitable happened, my wipers quit working. I took it apart and found the linkage broke on the end where the factory bushing goes. Well there isn't anyplace that sells one locally, and i figured if i buy one it'll probably wind up the same way, so i fixed the one i had and hopefully made it stronger in the process. I figured i would share my fix with you guys maybe you can use it later, so here goes.
this is the linkage with the end broke off of it, it split right in the middle of the hole the bushing goes into. the hole the bushing fits in is 9/16, so i went and picked up a couple of washers, i then took and line up the inside diameter of the washer with what was left of the linkage, and traced the outside diameter of the washer.
then took a grinder and cut it out to match the washer
with the bushing
here it is after welding both sides, and grinding it into shape, along side what i started with.
you can see how much material i left compared to what the it was from the factory.
coat of paint, finished.
re-installed, covered in white lithium grease.
total cost $0.48 for the washers
Default Re: windshield wiper fix
Old 02-08-2011, 09:15 PM   #2
Rep Power: 19 Old Dog is on a distinguished road
Good think'n I'm sure thats one we're all use.
Old 02-08-2011, 10:38 PM   #3
Now thats what I'm talking about! great job! This is the one that goes from the motor to the first blade??
Default
Old 02-09-2011, 05:50 AM   #4
Cheepjeep85
Yes sir. Im just waiting on the other linkage to break then it'll get fixed
Sent from my DROID2
Old 02-09-2011, 10:40 AM   #5
Here is the $64 question, why did it brake?
Default
Old 02-09-2011, 04:31 PM   #6
Cheepjeep85
No idea. Cheap stamped steel along with a minor water leak but that's just a guess.
Sent from my DROID2
Smile wipers binding 76 cj5
Old 01-27-2020, 07:32 PM   #7
elroy1 is offline
elroy1
Vehicle(s): 73 cj5,2015 wrangler
Rep Power: 0 elroy1 is on a distinguished road
i build a 76 cj5 . Bought a san juan tub complete with windshield, I bought new wiper motor and all linkeage. first time i used the wipers they bound up and quit working after a few miles.I took out the motor and the arm had come off the wiper motor. ordered new motor and when i installed it found that it moved when wipers worked.To make the story short the holes in the windshield was a 1/4in off where the motor bolts on.Not enough room to move the holes,so i added 1/4 in length to the short linkage problem fixed cost 00.00
fix , windshield , wiper
74 CJ5 -need windshield wiper parts es335 Chassis and Body 2 12-09-2012 12:28 PM
Windshield wiper switch issues. dabbrowne Misc CJ Discussion 12 11-21-2012 08:23 PM
How are the wiper motor wires routed to the wiper motor? suburban99 Chassis and Body 8 04-07-2012 05:06 AM
CJ5 windshield frame & windshield - hardtop 65reissue Chassis and Body 12 09-05-2011 12:13 AM
Small wiper link that bolts to wiper motor? suburban99 Chassis and Body 5 02-26-2011 03:19 PM
