Default Who has correct body mount bushings.
Old 05-19-2014, 03:42 PM   #1
aceves6 is offline
aceves6
Vehicle(s): 1976 Jeep CJ5, 232...all I know thus far.
aceves6's Avatar
Rep Power: 0 aceves6 is on a distinguished road
1976 CJ5, and I received mounts I cannot use. None fit in the stock mounting holes, the mounts are too wide and I need to smaller bushings for the two A mounts.
This is the kit I bought
Omix-Ada 12201.02 Body Mounting Kit
Had- YJ, Sport TJ, Rubicon TJ and now CJ5.
Default Re: Who has correct body mount bushings.
Old 05-19-2014, 06:24 PM   #2
Techlight is offline
Techlight
Vehicle(s): 1984 CJ7: 4.2l i6 (mild cam), Team Rush, Howell TBI, T5, D300, D30-front, AMC20-rear, 32/11.5/15 BFG A/T's........................ 1964 Kaiser CJ5 (sold), 1960 Willy's CJ5 (sold)
Techlight's Avatar
Rep Power: 7 Techlight is on a distinguished road
I'd contact whoever sold it for sure...maybe they sent you the wrong item? or wrong item was in the box (i've had this happen before).
Other option is a daystar mount kit although they are poly. They usually come with everything you'd need.
Good luck...hopefully someone can get you a part #. Another option is to call a local shop that you trust and ask if they can source the parts for you. I almost went this route when doing my bushings and I had a few shops that would do it for me, so it might be a feasible option for you.
If your working on the Jeep, remember...don't do anything the PO would have done!
Old 05-20-2014, 11:21 AM   #3
aceves6 is offline
aceves6
aceves6's Avatar
I think one of the issues with the kit I bought by Omix-ADA (12201.02) is they try to accommodate too many models/years with that kit and missed the mark on the CJ5.
I was able to track down the correct kit for my Jeep. Energy Suspension 2.4103G. Cost me $51 bucks, shipped. It has the two smaller mounts for the front and even has a grille mount. I hope this helps someone.
body , bushings. , correct , mount
advice on worn body bushings rockinreel Chassis and Body 9 05-22-2013 11:30 PM
Body Mount Bushings 1moreshot Chassis and Body 6 10-03-2012 06:38 AM
Body bushings - fiber tub install cwiehle0 Chassis and Body 5 12-05-2011 10:16 AM
Body mount DaBannerman Chassis and Body 3 09-01-2011 07:42 PM
Body Mount Hardware BLennon Chassis and Body 5 11-29-2010 09:41 PM
