Default Venting fuel tank
Old 07-13-2019, 11:21 AM   #1
Lutz is offline
Lutz
Vehicle(s): '78 cj-5 258, t-18, d30, d20
Rep Power: 0 Lutz is on a distinguished road
1978 pre-cat. Verified from Colorado state emissions. Registered collector vehicle.
Iím trying to properly vent the fuel tank. Liquid check valve/ rollover check valve hoses cut and plugged at tank.
Will a vented gas cap properly vent the tank, or do I need to re-install the check valve lines and run back to the charcoal canister with the vapor line?
And will the charcoal canister need vacuum to work properly?
Default Re: Venting fuel tank
Old 07-13-2019, 01:01 PM   #2
Lumpy Grits is online now
A vented gas cap will do the job.
Be very cautious about parking in a closed garage till the Jeep cools down after a drive.
fuel , tank , venting
CJ7 Fuel tank lloydwithAf Misc CJ Discussion 14 05-27-2015 06:37 PM
Fuel tank JimyB Misc CJ Discussion 2 03-20-2014 04:28 PM
Venting Gas Tank xena1 Drivetrain 15 05-08-2013 10:10 AM
Fuel Pressure from tank to fuel filter musicman72 Drivetrain 23 02-07-2013 09:20 PM
Fuel Tank / Fuel Mileage / Fuel Qty RedDog Misc CJ Discussion 4 11-03-2011 04:20 PM
