Default Stereo wiring
Old 03-24-2019, 01:53 PM   #1
Luke is offline
Luke
Vehicle(s): '85 CJ7
Rep Power: 0 Luke is on a distinguished road
I'm putting a new head unit in my 85 CJ7 and the old harness the PO put in got power and ground through the cigarette lighter. Just wanted to check and see if that is acceptable?
Default Re: Stereo wiring
Old 03-24-2019, 03:08 PM   #2
Cig lighter power is OK.
I would go with a dedicated GND.
Old 03-24-2019, 03:23 PM   #3
Luke is offline
Luke
Vehicle(s): '85 CJ7
Thanks LG. I always value your opinion on things.
Old 03-24-2019, 10:17 PM   #4
Fonchy is offline
Fonchy
Vehicle(s): 1981 CJ7, 258, 5 speed, 38dges carb, Dana 20 and Dana 300 1980 CJ5, 258, 4 speed, 1bbl
Rep Power: 0 Fonchy is on a distinguished road
I will use a dedicated wire for both. Cig lighter is ok but there is a radio wire that comes from the fuse box for power if not you can run a wire from the battery
Old 03-28-2019, 03:00 PM   #5
hollasboy is offline
hollasboy
Vehicle(s): '79 CJ5 I-6, 258
Images: 10
Rep Power: 0 hollasboy is on a distinguished road
My radio required 2 power inputs, one that is always on (for memory and clock) and one that is switched, coming from the fuse panel. I ran new dedicated wires to both. At the fuse panel, there was an unused "RADIO" pin that accepted my new wire (I do heat shrink connectors, and used a flat spade end to match the pinchers on the RADIO spot on the fuse block). The 'always on' wire I ran through the firewall to the battery (actually I have a power distribution block, but it's the same concept). I didn't need to fuse that line because the radio had an inline fuse already in it. Radios just run on 12 volts so any power source is good, as long as you don't overload that circuit. If you still have a working cig lighter, you run the risk of blowing a fuse if use it at the same time you are blasting your radio.
stereo , wiring
Stereo shanetheTRAIN46 Misc CJ Discussion 7 05-10-2017 04:36 PM
Stereo for CJ-7 dmcook Misc CJ Discussion 20 11-22-2012 10:26 AM
stereo systems rr41mag Misc CJ Discussion 12 09-15-2012 11:30 PM
jvc stereo problems iCEMAN Chassis and Body 2 04-26-2012 11:14 PM
cj stereo! how do you do it? snakes78cj5 Chassis and Body 6 10-17-2011 05:38 PM
