Question Replacing body mount bushings
Old 06-24-2014, 09:24 PM   #1
tireman74 is offline
tireman74
Vehicle(s): 1982 CJ5 4.2L i6 258 T-176 Dana 300 AMC 20 rear and Dana 30 front
Rep Power: 6 tireman74 is on a distinguished road
It's time to move on to the next project on the never ending list of things to do to a CJ.
Looking for advice on body mounts bushings, best kind to go back with and best way to change them.
Default Re: Replacing body mount bushings
Old 06-25-2014, 12:28 PM   #2
Munypit is offline
Munypit
Vehicle(s): 1985 CJ7, 258 engine, T176 tranny, twin sticked 300 transfer, 30/20
Rep Power: 7 Munypit is on a distinguished road
I just used the prothane kit ordered from Quadratech. Job took less than an hour. I used a 1/2 inch impact to remove all the old bolts, then used my floor jack and a piece of 4x4 to lift 1 side at a time. Don't tighten any bolts until you have all the bolts started all the way around the jeep. ( when picking up the body 1 side at a time the body tens to shift from side to side)
Old 06-25-2014, 01:50 PM   #3
tireman74
I know its personal preference on whether to go with rubber or poly, so tell me why you went with poly?
Old 06-25-2014, 03:50 PM   #4
Munypit is offline
Munypit
rubber deteriorates (sp.) quickly when it is contacted by oil and grease. Being a cj it is going to leak.
Old 06-25-2014, 04:00 PM   #5
tireman74
Have you had both? Can you tell a difference in the ride?
Old 06-25-2014, 04:33 PM   #6
Munypit is offline
Munypit
No I have not had both. Just my experience with rubber in an industrial environment, Mobile hydraulic equipment that gets a leak will desroy a set of rubber tires in no time. If you touch it it feels to be a tar like substance that will get on everything.
Old 06-25-2014, 04:47 PM   #7
tireman74
Thanks for the advice
Old 06-25-2014, 05:41 PM   #8
Rubber was OEM.
I went with the poly 20+ yrs ago, and very happy.
When your done-Spray'em heavy with silicon spray.
Old 06-25-2014, 09:12 PM   #9
tireman74
Should I replace the nuts and bolts or just use the existing ones? Also do either of you know what to torque the bolts down to? I can't find anything in the fsm that tells me.
Old 06-25-2014, 09:23 PM   #10
Only if they look bad.
The nuts are captive.
Use copper anti-seize on the threads.
Start soak'n the nuts and bolt NOW--
body , bushings , mount , replacing
Who has correct body mount bushings. aceves6 Chassis and Body 2 05-20-2014 11:21 AM
Aftermarket shackles, replacing bushings? Hitman1881 Suspension and Steering 26 01-27-2014 09:19 AM
Body Mount Bushings 1moreshot Chassis and Body 6 10-03-2012 06:38 AM
Replacing floor, supports, bushings and wheel housing Shrek Misc CJ Discussion 7 08-14-2012 11:22 AM
Replacing front sway bar bushings radman Suspension and Steering 16 04-01-2010 10:48 AM
