Default Questions About Front Disk Brakes
Old 11-18-2019, 07:22 PM   #1
Super8mm is offline
Super8mm
Vehicle(s): 1980 CJ5, 4 cyl, Borg Warner/Ford SR-4 4 spd, Dana 300 transfer case. Start a heart transplant mid November with LS1 and SM465 :-)
Super8mm's Avatar
Rep Power: 2 Super8mm is on a distinguished road
Looks like I need to replace my front calipers. When purging to flush out the brake system the front left only gives me a dribble and the right front I cant pull any fluid through it.
When looking I see there are 2 styles, Forward Mount and Rear Mount.
There they have Semi-Loaded but I don't know what is different about these and just plain ones?
How do I tell what mine are?
Default Re: Questions About Front Disk Brakes
Old 11-18-2019, 08:23 PM   #2
shum8 is offline
shum8
Voted most irritating
shum8's Avatar
Images: 2
Not sure about the forward / rear mount..... CJs never had rear disc brakes, that one has me stumped. Loaded I do believe means they come with the mounting pins. I bought loaded thinking that meant piston and seals...... nope. Mounting pins.
Old 11-18-2019, 08:27 PM   #3
Super8mm is offline
Super8mm
Super8mm's Avatar
The front brakes come in forward or rear mount.
I would have thought they would come with piston and seals, guess I had better look them up also Thanks
Old 11-18-2019, 08:28 PM   #4
shum8 is offline
shum8
shum8's Avatar
Images: 2
They all come with piston and seals....... I erroneously assumes only the loaded did. Loaded just refers to the mounting pins.
Old 11-18-2019, 08:41 PM   #5
Super8mm is offline
Super8mm
Super8mm's Avatar
Oh OK Thanks for the clarification.
brakes , disk , front , questions
Upgrading front drums to disc brakes should I also upgrade front axle to 4.10 76cj7chick Drivetrain 6 10-24-2017 12:12 PM
Front disk brakes rattle rockrazy1978 Misc CJ Discussion 0 04-24-2013 03:37 PM
Disk brakes vs Power Booster conversion baddiesel Suspension and Steering 8 08-01-2012 03:27 PM
SSBC Disk Brakes install on a AMC 20 Full Floating Axle JamesBryan Misc CJ Discussion 4 08-21-2011 08:36 PM
rear wheel disk brakes rotors and calipers IOPort51 Suspension and Steering 33 08-17-2011 08:52 PM
