Default ordering body mounts
Old 01-03-2020, 08:23 PM   #1
K9kodi is offline
K9kodi
Vehicle(s): 1986 cj7
Rep Power: 0 K9kodi is on a distinguished road
i've seen and read a lot on a yj tub on cj frame. what have y'all observed as being the way to go, order cj body mounts or yj. i suspect since it's a yj tub i would need to order the yj body mounts with the bolts since i don't have any bolts and i'm suspecting the yj tub has different bolt dimensions? i wonder if it would just make more sense to order the cj body mounts and find out what size bolts i need for the yj or order yj body bolts. i don't have the factory bolts to compare to.
Default Re: ordering body mounts
Old 01-03-2020, 08:37 PM   #2
shum8 is offline
shum8
Voted most irritating
shum8's Avatar
Iím running a YJ tub on a CJ frame..... and I bought new CJ mounts. As for the bolts - I do remember there being two sizes ( threads, not lengths), but I donít remember what the sizes were. I know, useless, right? The steel center ďtubesĒ will need to be cut shorter - Iíd have to dig thru my build thread to find the specs, and Gertís trimmed his way more recent than I - maybe heíll chime in shortly..... There will be 4 mount locations that will need to be moved a bit - two are on the rear crossmember. I had a new CJ crossmember so I moved the holes...... A new YJ crossmember would preclude your having to move those. I think the others are the most rearward before the frame rises over the rear axle. I believe there I slotted the hole on the bottom of the frame...... Again, Iíd have to go back and dig thru my build.
Hope this helps..... if not, just file under useless ramblings LOL
Old 01-03-2020, 08:50 PM   #3
K9kodi is offline
K9kodi
no your info reaffirms what i thought. i just wish i could get dimensions of the yj tub bolts and i'd buy cj body bushings
Old 01-03-2020, 08:54 PM   #4
shum8 is offline
shum8
shum8's Avatar
Yeah, I just took mine and matched new ones to what I had. I assume you still have the nut plates you could try bolts in? I think they were 1/2Ē and 7/16Ē....... Maybe
Old 01-03-2020, 10:08 PM   #5
K9kodi is offline
K9kodi
i could try that, but i was being lazy and not wanting to buy a number of different sizes , i'm not even positive on length
Old 01-03-2020, 10:36 PM   #6
K9kodi is offline
K9kodi
i did just find this. i'm wondering if they will still fit in the cj bushings
Old 01-03-2020, 11:16 PM   #7
shum8 is offline
shum8
shum8's Avatar
The bushings are just big ol rubber or poly bushings - those bolts will fit fine. Canít speak to the lengths, but the bolt threads sound right. Since the YJ tub is a direct swap for a CJ tub (with the exception of the couple mount locations) you should be good to go with those bolts.
Old 01-04-2020, 01:44 AM   #8
K9kodi is offline
K9kodi
awesome. cj mounts, yj bolts and we're rolling
Old 01-09-2020, 10:47 PM   #9
Masscj7 is offline
Masscj7
I believe this is what Shum was looking for in regards to cutting sleeves. Iíve had saved for months for mine.
Old 01-10-2020, 10:57 AM   #10
shum8 is offline
shum8
shum8's Avatar
That would be the one - Thanky. I got distracted and forgot to dig it up.......
body , mounts , ordering
Body mounts argo9372 Chassis and Body 15 03-14-2019 06:26 PM
Best body mounts jakeh937 Chassis and Body 49 06-18-2018 06:10 AM
Body mounts, which way.. Project86 Chassis and Body 4 03-06-2012 12:17 PM
body mounts givnerz Chassis and Body 2 12-22-2011 07:05 AM
Body mounts cj5ratt Chassis and Body 2 10-08-2011 07:12 AM
