Default Re: Oil Gauge wiring
Old 04-24-2019, 11:26 PM   #11
RiverandSand is offline
RiverandSand
RiverandSand's Avatar
Originally Posted by shum8 View Post
No, no - keep going. I for one find comfort knowing I知 not the only one with gauge issues. And with luck you値l find the problem and share the solution... win win.
I have no idea where I sent this from......
Agreed we come and go, I live the southwest so we jeep almost everyday or aleast try to. So I check in when I can. I had to replace my oil gauge because a PO installed a mechanical one which was a cheapie and didn't read accurately. I stayed mechanical and replaced it with Autometer as well as the volt gauge to match.
Have you tried Rockauto I have used them and I like the choices they give on parts, your usually not stuck just omix or crown.
Old 04-25-2019, 10:59 AM   #12
Tectron is offline
Tectron
Vehicle(s): 1980 CJ7, T176 Trans, 304 CID, 300 tc, Summit HEI Dist, Edelbrock intake, carb and cam, stock diffs 4.56 gears with Front and rear lockrites, Family Cage, 15x10x12.5 BFG MT's, 4" lift.
Tectron's Avatar
Rep Power: 2 Tectron is on a distinguished road
The Gauges in the jeep now are "Equus" , I don't know anything about there quality, but just to keep the gauges matching I think I'll get another one. If it fails I may just replace all the gauges at some point.
For a Free Jeep this thing is costing me a small Fortune
Default Speedo Gauge
Old 04-25-2019, 05:58 PM   #13
Tectron is offline
Tectron
Tectron's Avatar
Good news, Speedo cable installed without much trouble, it was broke at transfer case, I now know about how fast I'm going.
Default Re: Speedo Gauge
Old 04-26-2019, 02:07 PM   #14
RiverandSand
Still fighting mine, replaced my cable but it still works intermittently. I think the inside of the speedo gear in the TF case is bad. I need to change it anyway as the speedo was way off when it worked.
Old 04-27-2019, 10:59 AM   #15
Tectron is offline
Tectron
Tectron's Avatar
I haven't checked the accuracy on mine yet, curious to find out if its close.
Old 04-28-2019, 02:46 PM   #16
mdeluca is offline
mdeluca
mdeluca's Avatar
Rep Power: 4 mdeluca is on a distinguished road
I've got an 86 that had the, since removed, computer. It had the sensor pickup attached to the sender. I removed the sensor and installed a mechanical oil pressure gauge so I at least know what is really going on.
Purchased a new cheap gauge and sender from Crown at Quadratec and it worked for about 3 minutes... then the needle started bouncing all over the gauge.
I've decided to get a new MECHANICAL dash mount oil pressure gauge but don't like the looks of the autometer needle(will probably end up with it because I can't find anything else). I'm done with the sender baloney.
MY BUILD THREAD --- 1986jeeprestoration.blogspot.com
Old 04-28-2019, 05:16 PM   #17
I put a Sunpro in mine that I got from one of the part stores.
The Following User Says Thank You to mtnwhlr For This Useful Post:
mdeluca (04-28-2019)
Old 05-19-2019, 09:27 AM   #18
Tectron is offline
Tectron
Tectron's Avatar
Good news, Oil Gauge works, so nice knowing my engine is pumping oil
gauge , oil , wiring
Temp gauge wiring Tectron Chassis and Body 34 05-19-2019 09:24 AM
RPM Gauge Wiring ThisGuyUKnow Chassis and Body 4 12-21-2013 10:23 AM
Fuel gauge and Temp gauge still dont work? peterb Misc CJ Discussion 18 06-07-2013 04:10 PM
Oil Pressure Gauge Wiring bntcrkfrm Misc CJ Discussion 4 05-04-2012 09:10 PM
Wiring q's for the wiring masters w/pics 78cj5 Chassis and Body 10 11-01-2009 09:00 PM
