Default Need headlight adjustment help
Old 11-30-2019, 07:17 PM   #1
JeeperChris is online now
JeeperChris
JeeperChris's Avatar
My Low Beams were a bit high so I adjusted them down this morning. The little plastic forty year old "nuts" stripped right out and the parts store has no listing for anything Jeep in that related category.
So what do you guys use to replace those little plastic nut thingies? Mine look like they are riveted in with three rivets and more round than square like the replacement ones the parts store had.
Default Re: Need headlight adjustment help
Old 11-30-2019, 07:47 PM   #2
Manic Mechanic is online now
Manic Mechanic
Manic Mechanic's Avatar
Images: 11
I bought this kit from Morris 4x4 it requires u to drill out the rivets and use the 2 supplied nut and screws to hold them in. Not factory but works well for less than 20 bucks
Old 11-30-2019, 08:26 PM   #3
JeeperChris
that's awesome! Thank you. I looked through Quadratech but had not gotten to Morris yet.
Now I just need to Jimmy-Rig something until that kit gets here..... ;-)
Old 11-30-2019, 08:50 PM   #4
Manic Mechanic
Images: 11
I tried to Jerry rig alot of things none worked
Old 11-30-2019, 09:12 PM   #5
JeeperChris
Yeah, my mind is running through a lot of things right now. I'm thinking of trying the generic plastic pieces the parts store has. If it doesn't work then I'm only out a couple of bucks. If I make anything work I'll throw up a pic tomorrow.
Old 12-01-2019, 01:46 PM   #6
JeeperChris
I figured something out.
I drilled out the rivet on one of them and was trying to fit in a replacement piece for a standard GM application since it's the only ones the part store carried. Didn't work but I realized something -- if you take a couple small zip-ties and run them through the original threaded hole, then screw from the newer replacement unit will work. The newer screws are smaller size so it all fits together perfectly.
Old 12-01-2019, 01:47 PM   #7
JeeperChris
Old 12-01-2019, 01:48 PM   #8
JeeperChris
Now I'm off to the hardware store to get a small screw and nut to bolt this original piece back on. I didn't have to drill out the rivet at all but I didn't think of the zip tie idea until after the drilling.
So now we know.
I'll post a pic of it when I'm done to and confirm whether it works or not.
Old 12-01-2019, 03:40 PM   #9
JeeperChris
Ok, so I didn't take a pic when I got it all back together before covering it with the ring, but it works like a charm!
Old 12-02-2019, 05:33 AM   #10
Scout1067 is offline
Scout1067
Scout1067's Avatar
Images: 3
When I got my CJ last year the headlight mounts were so rusty they weren't even worth trying to save so I bought the Rugged Ridge replacement mounts. They ran about $90 but were worth it
The Following User Says Thank You to Scout1067 For This Useful Post:
JeeperChris (12-02-2019)
adjustment , headlight
Camber Adjustment IowaCJ5 Suspension and Steering 2 07-09-2013 09:46 AM
Clutch adjustment STEVE1103 Drivetrain 1 05-05-2013 03:57 PM
steering box adjustment mikemrq Suspension and Steering 3 12-29-2012 10:03 AM
Valve adjustment dadawg Drivetrain 1 04-03-2012 09:13 PM
clutch adjustment 79cj5 Drivetrain 2 10-17-2009 04:17 PM
