Default High Output Alternator Wiring
Old 07-26-2019, 07:38 PM   #1
jzak is offline
jzak
Vehicle(s): 1981 CJ5/258 4.2L I6, Tremec T-176 4-speed, Dana 300, Power Steering, Howell Throttle Body Injection System, Warn Locking Hubs, Warn Rock Crawler front/rear bumper with Tire Swing Carrier, Full Roll Cage, Pro Comp ES9000 shocks
jzak's Avatar
Rep Power: 7 jzak is on a distinguished road
Hey Guys,
Just bought a Powermaster 120 amp alternator, and I'm wondering if I need to upgrade the factory wiring. If so, what gauge cable do you recommend?
Thanks!
Josh
Default Re: High Output Alternator Wiring
Old 07-26-2019, 08:22 PM   #2
Manic Mechanic is offline
Manic Mechanic
Vehicle(s): 85 CJ7 4.2L 258 .040 over, T-5 trans, dana 300, dana 30 front 3.23 and lock right locker, rear stock amc 20 3.23 traclock 79 CJ7 304, th400 auto borgwarner 1389?? qudratrac stock rest unknown. 89 YJ 4.2L 258, AX-15 5spd, NP231, dana 30 front, dana 35 rear with posi, gears unknown
Manic Mechanic's Avatar
Images: 11
Rep Power: 4 Manic Mechanic is on a distinguished road
I ran factory with mine.
The Following User Says Thank You to Manic Mechanic For This Useful Post:
jzak (07-26-2019)
Old 07-26-2019, 10:01 PM   #3
JeeperChris is offline
JeeperChris
JeeperChris's Avatar
I've been thinking about an upgrade to the alternator. What did you get? What are some good options out there?
Old 07-26-2019, 10:31 PM   #4
jzak is offline
jzak
jzak's Avatar
Hey Chris,
I got the Powermaster 7288. I spent hours trying to find something that was 100+ amps and was sure to fit. BTW Amazon vehicle filter is BS. I figured the 7288 is double the amperage of my old alternator but not ridiculously expensive ($170).
I know its a losing battle for an alternator to keep up with a winch, so i'm focusing on something that can keep up with my off-road lights, radio, etc.
I'll let you know when it comes next week, if I made the right choice.
Cheers!
https://www.jegs.com/i/Powermaster/713/7288/10002/-1
Old 07-27-2019, 06:20 AM   #5
JeeperChris
Good luck with it, can't wait to hear the results!
Old 07-27-2019, 09:44 AM   #6
Belizean is online now
Belizean
Belizean's Avatar
^^^ x2
Old 08-01-2019, 03:38 PM   #7
jzak is offline
jzak
jzak's Avatar
Looks like I'm having one of those weeks guys. The alternator doesn't fit. The hinge bolt connects perfectly, but the top hole that screws into the belt tension adjuster channel is way off. the hole sticks out about an inch higher, which makes sense considering the alternator is much larger in diameter than the factor one. I guess I would have to buy a larger alternator bracket for it to fit. Looks like I'm sending another one back to amazon!
Old 08-01-2019, 06:50 PM   #8
JeeperChris
That sucks! Sorry to hear it Dude. I was kinda wondering if a higher amperage alternator would be physically bigger than the oem.
The Following User Says Thank You to JeeperChris For This Useful Post:
jzak (08-01-2019)
Old 08-01-2019, 07:34 PM   #9
jzak is offline
jzak
jzak's Avatar
Thanks! I'm sure there's gotta be somebody selling a conversion bracket out there. The alternator is exactly the same as the factory one, except that its bigger in diameter.
Old 08-01-2019, 08:08 PM   #10
Manic Mechanic
Images: 11
I'll try to remember tomorrow when I get home to take a pic of mine should still have the part numbers on it
jzak (08-01-2019)
alternator , high , output , wiring
High Output Alternators? jzak Chassis and Body 11 12-24-2015 10:32 PM
stock alternator output 1984 CJ7 Chassis and Body 9 12-12-2012 11:51 PM
Alternator wiring ftwflh Chassis and Body 5 02-11-2012 03:59 PM
Alternator wiring alaskaviper Chassis and Body 0 08-13-2011 02:35 AM
high output alternators advice kickitandholdit Drivetrain 4 07-23-2011 07:07 PM
