Default Heater (Blower Motor) Wiring
Old 10-25-2012, 09:18 AM   #1
musciab is offline
musciab
Vehicle(s): 1974 CJ 5, 6 cyl 3 speed, AMC 20 Rear, Dana 30 Front
musciab's Avatar
Images: 7
Rep Power: 0 musciab is on a distinguished road
Ok, finally got the rear end finished and need some heat for the winter. I have pulled the heter assy out of my CJ5 and took the motor off and tested it to make sure it worked. I added a pig tail to the only connector on the motor so i dont have to take the housing back out to get it wired up. I also added a ground wire to one of the bolts on the motor and will attach that somewhere.
Now my question....If you look at the pics attached i have a the 3 pronged resistor on my housing and what it looks to be the original connector from the wiring harness. Also i have what it looks to be the original connector for the blower motor switch from the wiring harness. For the resistor connector, there are 4 wires to it and the switch connector also has 4 wires. Where does my motor get tied into???? I have not checked to see if any of the wires h ave power bc my meter is acting up. If someone could explain what wire does what and what wire is supposed to hook up the motor, i would be most greatful. Thanks.
Default Re: Heater (Blower Motor) Wiring
Old 10-25-2012, 10:33 AM   #2
csuengr is offline
csuengr
Vehicle(s): 1980 CJ-7 LT1 TF727 NP231-D300 Waggy D44's ARB's 35" tires
csuengr's Avatar
Rep Power: 9 csuengr is on a distinguished road
Your fan should have only one wire going to it. From your wires, it should be a lt brown/blk. Power goes from the switch, to the resistor, and then to the motor.
Old 10-25-2012, 11:36 AM   #3
musciab is offline
musciab
musciab's Avatar
Images: 7
So can i splice into he lt brown/black wire or am i missinge something? If i splice into that wire wouldnt i bypass the resistor? Am i missing a connection coming from the resistor to the motor is my real question?
Old 10-25-2012, 12:06 PM   #4
billyocup is offline
billyocup
Vehicle(s): 75 CJ5 304V8 T15 D20 D44 D30 2 1/2" lift, 05 Victory Kingpin, 2011 GMC Sierra 3500 Diesel 4x4
billyocup's Avatar
Rep Power: 9 billyocup is on a distinguished road
Based on my 75, I would guess your heater and your wiring harness have been upgraded at some point. The original (stock) would have been a 2 speed switch with the resistors built into it and the blower motor would have had 2 wires and a ground.
I just changed out my wiring harness to a new Painless harness and it was set up like yours for a 3 speed switch with a separate resistor unit.
Anyway, I used the attached wiring diagram to hook everything up and it worked out fine. I had a light brown wire marked heater blower on my harness that was in the engine compartment ( the later model CJ's the blower motor goes through the firewall) that I re-routed back into the cab and hooked up to the HI lead on my existing 2 wire motor.
Hope that helps some - Bill
Old 10-26-2012, 06:50 AM   #5
musciab is offline
musciab
musciab's Avatar
Images: 7
Thanks Billy. i tried taking a look at this last night but wasnt able to due much. Tonight or this weekend i will get to it , hopefully. My wire colors dont match up to that diagram and instead of two wires coming out of one of the leads on the switch (im assuming 1 for the motor), my harness has them coming out of the resistor, which makes no difference according to your diagram. Now i have to cut all of the tape holding my harness together and try and trace the wires to find the missing open end that attahced the motor to everything else. Thanks for the help and let me know if you can think of anything else that may be of assistance.
Old 10-29-2012, 10:21 AM   #6
musciab is offline
musciab
musciab's Avatar
Images: 7
Got the chance to get working on this over the weekend, thank god becasue its getting cold and wet up my way. Anyways, i ripped into my wiring harness and traced the swithc wires and the resistor plug wires to the correct places.....except for one of the wires going from the resistor plug that needed to be connected to my motor was taken directly to my bulk head. Upon further review, the bulk head wire went to an open wire just hanging in my around my engin. So what i did was clipped the wire near the bulk head and took it directly to my blower. To my suprise it still didnt work. Got my meter out and found that i had a bad connection at my fuse block. had to sand some corrosion away and now.......IT WORKS!!!!
Still need to fix it up a bit so it doesnt look like an amature did it (even though i am). Now question, is there supposed to be a hole in my firewall to connect the wire from my bulk head to my blower? I ask this becasue of the way it was set up and i found that the connector on the blower is now smashed against the firewall. If there is supposed to be a hole there how do i seal it up so i dont get water in it? Thanks for all the help guys.
Old 10-29-2012, 07:25 PM   #7
Flex BT is offline
Flex BT
Vehicle(s): 1981 CJ7. I6, Weber 38/38 with TEAMRUSH upgrade. T5, Dana 300TC, Dana 30 / AMC 20, True trac w/ 4.10s. 33" All terrains Blue and rust colored.
Rep Power: 8 Flex BT is on a distinguished road
Hmm, I just did the Blazer upgrade on my CJ7. If the 5 is like the there should be a big hole where the blower motor is and a smaller hole at about 4:30 to the first looking at the firewall from the front bumper. That is where the power for the blower motor goes with a quick connect. The motor should have a seal on it that includes a space for the small cylinder for the power connection. I'm guessing your PO may have installed the motor from a 7 and your 5 doesn't have the same hole. Can a 5 owner confirm / deny?
Old 10-30-2012, 02:15 PM   #8
musciab is offline
musciab
musciab's Avatar
Images: 7
Thanks. The PO installed a new fiberglass tub and he told me that he just needed to connect the power to the motor. I didnít know that the power wire came in from the engine compartment. This all makes sense to me now. I was on my way to work this morning and realized that my blower wasnít working again and with the hurricane in our area, we got some snow. Luckily I only live 5 mins from work. I think my fuse block is a little corroded and with the cold, it just stopped. I have some fine sand paper that Im going to hit it with to make sure thatís all it is. Cross your fingers.
Old 12-20-2012, 12:27 PM   #9
frhrwa is offline
frhrwa
Vehicle(s): 1984 CJ-7 (just bought it, so I have to do some work and see what it has in it.. other than 4.2L Auto.. 4" lift, 33" tires... my '75 had a 304 2" Burbank supspension, warn winch, full cage, all the goodies, the '79 had a 401 turbo charged hi-po with t98 or 18, which ever one had the granny low first gear (never can remember which).. had all the items needed to 4wheel, none of the show and go poopie.. I don't believe "chrome will get you home"! I'm also not one to go out to see if I can tear up my jeep, I go where I must, usually with a group that I hung with.. Used to be part owner in Diablo Off Road Center in Concord California.. Jack Essex owned Diablo 4WD, George Clause was Mr. Base CAmp, and mine was "Sounds Etc" all under one big roof "the Diablo Off Road Center"..
frhrwa's Avatar
Location: Pacific (NorthEast) Washington and Las Vegas 1/2 year..
Images: 6
Rep Power: 9 frhrwa is on a distinguished road
looking at that picture with the 3 wire plug, it goes on the outside of the upper housing, then on the inside is another plug receptacle, what plugs into it? I cannot find another plug to put there? it would be on the inside of the blower box ..
Old 12-23-2012, 02:54 PM   #10
frhrwa is offline
frhrwa
frhrwa's Avatar
Images: 6
this conversion is almost a "must do".. it makes so much difference, you won' believe you ever drove a jeep in the winter without it?
blower , heater , motor , wiring
heater blower motor pm102 help 1984 CJ7 Chassis and Body 2 11-29-2012 06:25 PM
Heater blower motor replacement Dlowe Chassis and Body 2 09-26-2012 04:49 PM
Heater Blower motor upgrade Dlowe Chassis and Body 3 12-09-2011 08:04 PM
1976 CJ5 Heater blower (motor) aceves6 Chassis and Body 9 07-13-2011 11:26 PM
My Blazer Heater Blower Motor Upgrade ThisGuyUKnow Technical Threads 16 04-08-2011 08:23 PM
