Default H4 bulb and relay wiring question
Old 01-15-2020, 12:12 PM   #1
smokedoff is offline
smokedoff
Vehicle(s): 83 cj7
Rep Power: 0 smokedoff is on a distinguished road
I think Iím going to do new lenses, h4 bulbs, new plugs, and the Daniel stern type replay setup on my cj7. My plan is to come off + battery, then fuse, run power wire along firewall toward fuse box on driver side. Mount relays on the rear side of the driver fender well, kinda facing brake reservoir. Then go into factory headlight harness with wires to the front.
My question is, how far on the switch side do I need to go for wiring? All the way to the dimmer switch in the floor? Just to the fuse box? Can I tie factory wires from fuse box to new wire going to the relays?
Also, would you use 12ga wire throughout, or 12 batt-relays-lights and maybe 14 switch to relay?
Default Re: H4 bulb and relay wiring question
Old 01-15-2020, 05:09 PM   #2
Basod is offline
Basod
Basod's Avatar
If your stock harness is in decent condition just run the fused hot to the relay pin 30 and the gray from bulkhead connector to low beam relay term 86 then the gray to headlights to relay pin 87.
The gray with the tracer is high beam and wires the same way on a separate relay.
I wouldn't bother with 12ga wire until you tested for voltage at the light connectors after installing the relays - there's not really enough distance there that 16 vs 12 going to make a difference. If the connectors are all corroded than that is a different story
Old 01-15-2020, 06:08 PM   #3
Patrick is offline
Patrick
Patrick's Avatar
How about branching off the alternator output lug?
Old 01-15-2020, 06:11 PM   #4
smokedoff
Vehicle(s): 83 cj7
Why this as opposed to battery? I plan to put a fuse block near the battery for some other accessories as well as my headlight wiring. I was gonna come off battery, make that block hot, and feed from there.
Old 01-15-2020, 06:18 PM   #5
Patrick is offline
Patrick
Patrick's Avatar
Just to take the voltage drop issue a step further. Thatís it.
Old 01-15-2020, 06:50 PM   #6
smokedoff
Vehicle(s): 83 cj7
When Iím at the partís store, what do I need specifically in regards to the h4 bulbs? Arenít there a few different ones?
Old 01-15-2020, 08:27 PM   #7
Patrick is offline
Patrick
Patrick's Avatar
Just ask for the h4 light bulb connector. The original connector on your harness might be compatible. Your vehicle was not originally equipped with h4 bulbs, unless you upgraded it.
Old 01-15-2020, 08:36 PM   #8
smokedoff
Vehicle(s): 83 cj7
Are all h4 bulbs the same?
Old 01-15-2020, 08:54 PM   #9
I put my relays on my radiator core support, I pulled my signal wire directly from the headlight plug and the power and ground straight from the battery I think I used 14 gage maybe, works great
Old 01-15-2020, 08:59 PM   #10
Patrick is offline
Patrick
Patrick's Avatar
They share the same connector arrangement.
bulb , question , relay , wiring
Hazard relay / Turn Signal Relay Mick Chassis and Body 6 11-12-2013 05:34 PM
HEI relay and Choke Relay. Jimbos76cj Chassis and Body 10 10-03-2013 02:08 AM
Heater Relay Upgrade Wiring install for cj7 76cj7chick Any and ALL Aftermarket Parts and Additions 30 04-20-2013 02:51 AM
Lokar N/S Relay Wiring?? 76cj7chick Chassis and Body 8 09-27-2012 01:56 AM
led replacement bulb ie 1157 bulb and 194 bulb robert1973 Chassis and Body 2 12-25-2010 09:36 PM
