Default Re: H.E.I wiring question
Old 10-31-2019, 08:22 PM   #11
Manic Mechanic is offline
Manic Mechanic
Manic Mechanic's Avatar
Images: 11
Question did you set the timing with the vacuum advance hooked up or plugged off?
U need to plug it then set the timing but only once it's up to operating tempture
Old 10-31-2019, 08:55 PM   #12
bender3 is offline
bender3
Vehicle(s): 81 CJ7, .258, SR4 (boo), D300,
Rep Power: 0 bender3 is on a distinguished road
Disconnected the vacuum advance, plugged it off and set the idle to 700 before setting the timing. After the engine was at operating temp. That's why i'm scratching my head. I thought I'd done everything right....but i'm missing something.
Old 11-01-2019, 12:59 PM   #13
R717 is offline
R717
Vehicle(s): 86 CJ-7, 258, junkyard HEI, Weber DGEV, T5, D300, D30/D44, OME YJ lift springs, BFG 33x12.5 A/Ts
R717's Avatar
Rep Power: 0 R717 is on a distinguished road
Need a better description of the symptoms. Double check your terminations for power to the distributor. Be sure you pulled power from a reliable and adequate source. To rule that out you can run a wire directly from batt pos to the distributor and test drive.
Sounds more likely to be fuel side to me. Check: fuel fliter (return nipple above the supply nipple), float level, fuel press if you have a gauge.
Also not a bad idea to buy/borrow a dial back timing light, rev the engine to 3500 and see where timing is (vac adv disconnected).
h.e.i , question , wiring
LED resistor and wiring question 76cj7chick Body, Electrical, Chassis 17 09-25-2018 07:43 PM
Another Question? Wiring 45frank Chassis and Body 4 04-16-2017 04:50 PM
CJ Wiring Question Rescue Diver Chassis and Body 25 10-27-2013 03:51 PM
Wiring Question cjmadness Chassis and Body 13 09-24-2012 12:55 PM
73 cj5 wiring question asphaltaddict Chassis and Body 10 05-31-2010 07:30 PM
