Default Gauge lighting
Old 02-26-2020, 06:50 PM   #1
wingrph is offline
wingrph
Vehicle(s): '84 CJ7
Rep Power: 0 wingrph is on a distinguished road
Hello, I have an 84 CJ7. I need some help trouble shooting lighting issues with my gauges. Currently the gauges work properly, but the lights do not work. I know the lights should work because I just replaced the small gauges with new ones and they worked before I changed them. What could be the issue? How can I fix them? Please help. Thanx!
Default Re: Gauge lighting
Old 02-27-2020, 06:07 AM   #2
Scout1067 is offline
Scout1067
Scout1067's Avatar
Images: 3
First and always, check the ground. That's what I would do anyway.
Sent from my SM-A405FN using Tapatalk
Old 02-27-2020, 10:51 AM   #3
Basod is offline
Basod
Basod's Avatar
There is one accessory lamp fuse, be a good place to start. Sometimes the base of the fuse connector can corrode so remove and check the base of the fuse as well as continuity.
Attached is a wiring diagram for an 86 - but the same layout for an 84.
Welcome as well - I'm right down I20 by Oxford/Anniston.
Old 02-27-2020, 01:17 PM   #4
TnCJ is offline
TnCJ
TnCJ's Avatar
Rep Power: 2 TnCJ is on a distinguished road
^^^^^What he said^^^^^
I changed all mine out a couple of months ago and ran into the same problem. Finally traced it down to a bad ground connection.
IIRC, they all share a common ground.
gauge , lighting
CJ5 Speedometer Lighting skydivebob Chassis and Body 2 05-18-2019 07:42 AM
lighting and electrical woes Helomedic1171 Chassis and Body 50 01-08-2016 10:04 PM
Led lighting? LIVELY5R Chassis and Body 5 08-01-2014 06:47 PM
Garage Lighting Tin Medic Shops, Equipment and Tools 2 07-11-2013 09:22 AM
Lighting Problem... 78cj5frankenjeep Chassis and Body 5 08-07-2011 04:13 PM
