Default which fuel tank is this?
Old 07-21-2019, 02:51 PM   #1
lowcountry is offline
lowcountry
Vehicle(s): '83 CJ7, 258, D30, amc 20, D300, 4sp, '70 Z28, LSX, 6sp, 711 fwhp (N/A), 2015 2500 HD Duramax/Allison
Rep Power: 1 lowcountry is on a distinguished road
15 or 20? I searched 20 pages of related posts. Saw one that looked like this one, but no one said what capacity it was...
Not the best picture, but it's an OE poly tank in a steel cage. OD is ~ 28x17x15. The dimensions are too irregular to get numbers to calculate volume...
thanks.
If you don't know where you're going, any road will do...
Default Re: which fuel tank is this?
Old 07-21-2019, 02:56 PM   #2
coldair is offline
coldair
coldair's Avatar
Images: 44
Looks like my stock 20 gallon tank
The Following User Says Thank You to coldair For This Useful Post:
lowcountry (07-21-2019)
Old 07-21-2019, 04:07 PM   #3
20 gal.
Old 07-21-2019, 04:56 PM   #4
lowcountry
Thanks guys - confirmed my guess...
Old 07-21-2019, 05:03 PM   #5
Just make sure the fill/overflow inlets are not cracked at their base.
fuel , tank
Fuel tank weithman5 Drivetrain 10 12-14-2017 11:49 PM
CJ7 Fuel tank lloydwithAf Misc CJ Discussion 14 05-27-2015 06:37 PM
76 fuel tank driver007 Chassis and Body 3 04-07-2015 11:50 PM
Fuel Pressure from tank to fuel filter musicman72 Drivetrain 23 02-07-2013 09:20 PM
Fuel Tank / Fuel Mileage / Fuel Qty RedDog Misc CJ Discussion 4 11-03-2011 04:20 PM
