Default Electric Fan
Old 02-17-2012, 03:06 PM   #1
tonkatrucksryan is offline
tonkatrucksryan
Vehicle(s): 1975 CJ5 w 4.2 258. 2004 TJ Rubi 2011 Toyota Tundra
tonkatrucksryan's Avatar
Rep Power: 8 tonkatrucksryan is on a distinguished road
I am thinking about installing an electric fan on my 75cj5 It has a 4.2 in it. What brand should I look for and how hard is it to install? Do I just take the four bolts off the fan blades and leave the pulley. I am really nervous about this one....
Default Re: Electric Fan
Old 02-17-2012, 03:16 PM   #2
JR74CJ5 is offline
JR74CJ5
Missing-Presumed Wheeling
JR74CJ5's Avatar
Rep Power: 11 JR74CJ5 is on a distinguished road
There's tons of info out here on the ford Taurus electric fan or contour dual electric fan junkyard swap.
I did a fair amount of research on it, including the wiring details etc.
I believe "Jeephammer" has done some real good write-ups and wiring diagrams on jeepforum
Heres one (Not from Jeephammer, but still good one with some interesting twists): Ford Taurus Fan Install
and Just google "Electric fan swap cj" you should get enough to read about for hours. (I did )
I'll try to search up and re-find some of the better ones i found for you.
Here was the thread with some of my research and links: http://www.jeep-cj.com/forums/f2/clu...lectric-11419/
~ JR
JR - ECV3
My Build< Click me
Old 02-17-2012, 03:19 PM   #3
One of the best electric fan swaps for a CJ is from a Ford Contour. The are write-up all over about this swap.
Here are a few threads on it.
http://www.jeep-cj.com/forums/f2/contour-dual-fan-5169/
http://www.jeep-cj.com/forums/f99/us...-665/#post3084
http://www.jeep-cj.com/forums/f49/an...question-8743/
Old 02-17-2012, 03:21 PM   #4
CJim7 is offline
CJim7
CJim7's Avatar
Rep Power: 10 CJim7 is on a distinguished road
Those 4 bolts secure the pully to the water pump. Simply remove the fan and re-install the bolts.
<img src=http://www.pixeldecals.com/shop/image/cache/data/flipoff_smiley_3c-400x400.jpg border=0 alt= />
Old 02-17-2012, 03:24 PM   #5
tonkatrucksryan
I want to buy a new electric fan from morris 4 x 4 or quadratec. One specific for the cj. Any ideas
Old 02-17-2012, 03:30 PM   #6
Buy a new contour replacement fan instead. It fits as well (or better), pushes more air and can be replaced if broken by ordering from any parts house.
Old 02-17-2012, 03:47 PM   #7
tonkatrucksryan
For what year contour should I order?
Old 02-19-2012, 10:52 PM   #8
jasonmark1993 is offline
jasonmark1993
Vehicle(s): FJ cruiser (wifes ride) 2008 ZX10R, 73 CJ5, 408W, Toploader, Dana 20, 9" Dana 30 5.38 gears, next purchase=slicks
jasonmark1993's Avatar
Rep Power: 9 jasonmark1993 is on a distinguished road
Youre on the right track now Tonka. DO NOT get a generic fan that is secured through the core. I havent done this particular one but Im guessing the nice shroud on a factory contour one can be modified to bolt to the rad.
Either jegs or summit sells an improved control system now too; I think its by flex a lite. The common relay system isnt the best because you get a big 100amp hit when the fan starts. Ive used a delta current controller before and was happy with it.
Old 02-20-2012, 01:14 AM   #9
Who has done the contour swap with a 4.2??
I seem to remember it being done with a V8 but I think the l6 is a bit closer to the radiator.
Please correct me if I am mistaken.
I used a Taurus fan and had to be rather creative with the placement of it.
Old 02-20-2012, 12:37 PM   #10
95 - 97 V6 fan.
electric , fan
Electric fan drivert51 Drivetrain 12 08-17-2012 07:55 AM
Electric fan help poser Drivetrain 2 09-11-2011 10:32 PM
Electric Hubs for CJs GatorBate Drivetrain 16 02-02-2011 10:41 PM
Electric Fan HELP!!!! dave pam Jeeps other than CJ's 5 09-06-2010 10:44 PM
Electric Water Pump vs Electric Drive kit jeep cj7 304 Drivetrain 8 01-30-2009 10:03 PM
