Default Daystar replacement body mounts
Old 02-25-2014, 12:41 AM   #1
billyballer is offline
billyballer
Vehicle(s): 1986 CJ7: Renix 4.0 swap. 1969 MGB GT 1974 Capri race car 1970 Lotus Elan 1959 Lambretta
billyballer's Avatar
Images: 3
Rep Power: 10 billyballer is on a distinguished road
I'm thinking about putting some new body mounts on my '86 CJ7 and I was curious if any of you have had experience with the Daystar replacement mounts KJ04002BK, not the 1" body lift, just stock replacement mounts. I was curious if it nets any lift at all or if the mounts are indeed the same height as the stock rubbers. I wouldn't mind gaining an extra 1/2", but really don't want to do the full 1" body lift (although I had considered buying it and cutting it down) as I don't want to mess with linkage, lines or wires at all.
Current setup is 2.5" lift with 1/2" lift shackles and 31's but I'm hoping to go up to 32 or narrow 33" tires.
Let's hear what you think.
-Bill
Default Re: Daystar replacement body mounts
Old 02-25-2014, 07:48 AM   #2
caveman is offline
caveman
caveman's Avatar
Original body mounts will squat over time and new ones may give you the 1/2 inch that you want or close to it. I've run daystar products and have never had a problem with them.
The Following User Says Thank You to caveman For This Useful Post:
billyballer (02-26-2014)
Old 02-25-2014, 03:39 PM   #3
PaRenegade is offline
PaRenegade
PaRenegade's Avatar
Images: 20
Rep Power: 10 PaRenegade is on a distinguished road
It's not a "given" that you'll have to lengthen anything if you go with a 1" bl. I've heard of many that had no problem, but all Jeeps aren't created equal. I put a 1" Daystar lift on mine and foresee no issues yet (I'm still assembling) but then my Jeep never had a "previous owner" either.
The Following User Says Thank You to PaRenegade For This Useful Post:
Old 02-26-2014, 08:54 PM   #4
billyballer
Images: 3
Well I went ahead and ordered the Daystar stock replacement body bushings. I'll report back in a few weeks with results and pictures.
-Bill
Old 04-16-2014, 03:09 AM   #5
billyballer
Images: 3
Just wanted to post an update.
I finally got around to installing the Daystar stock replacement urethane bushings (black). I added a single fender washer at the top of the bushings as well. Measured height at all 4 corners before and after and gained between .75" -1" depending on the corner. My old rubber bushings were really shot, so the extra height isn't surprising. But I think it is safe to say that the stock daystar bushings are good for a small boost in height.
Looks like I should clear 33"s now with my 2.5" lift springs, .5" lift from shackles plus the small boost from the Daystar kit.
-Bill
The Following User Says Thank You to billyballer For This Useful Post:
Agent915 (05-22-2017)
body , daystar , mounts , replacement
Daystar 1" Body Lift gopbobby Chassis and Body 4 10-06-2012 12:47 AM
Body mounts, which way.. Project86 Chassis and Body 4 03-06-2012 12:17 PM
body mounts givnerz Chassis and Body 2 12-22-2011 07:05 AM
Body mounts cj5ratt Chassis and Body 2 10-08-2011 07:12 AM
custom body mounts Old Dog Sand, Dirt and Mud 9 04-22-2011 10:00 PM
