Default Daystar body mounts and lift
Old 01-27-2020, 10:34 PM   #1
Masscj7 is offline
Masscj7
Images: 10
Anyone have experience with them. I can’t understand why some lift pucks are 1 15/16” others are 2 15/16” and the body mounts themselves are about 2 1/4”? So none match up at all. I would think that you would make the lift pucks the same diameter of the body mounts.
Default Re: Daystar body mounts and lift
Old 01-28-2020, 05:03 AM   #2
Manic Mechanic is offline
Manic Mechanic
Vehicle(s): 85 CJ7 4.2L 258 .040 over, T-5 trans, dana 300, dana 30 front 3.23 and lock right locker, rear stock amc 20 3.23 traclock 79 CJ7 304, th400 auto borgwarner 1389?? qudratrac stock rest unknown. 89 YJ 4.2L 258, AX-15 5spd, NP231, dana 30 front, dana 35 rear with posi, gears unknown
Manic Mechanic's Avatar
Images: 11
Rep Power: 4 Manic Mechanic is on a distinguished road
I'll have to check but if I remember correctly some of the body mounts are lower than others depending on their location on the frame. But it's been years since I have done a body lift.
Old 01-28-2020, 01:40 PM   #3
Mrpeter63 is offline
Mrpeter63
Vehicle(s): 1983 CJ7, 4.2, T999, D300, AMC20, D30
Rep Power: 0 Mrpeter63 is on a distinguished road
Hmmmm, that is strange. I would say if you have 2 larger ones they go in the front and if you have 4 larger ones, front and rear. Just thinking that way because those locations have a larger surface area on the body..
Old 01-29-2020, 11:02 PM   #4
Masscj7 is offline
Masscj7
Images: 10
As I worked through them, I agree, smaller pucks are for rear 4 mounts. Those fit perfect. The larger pucks do look a little silly on top of the smaller mounts, but it does spread the contact patch on the body over a larger area.
body , daystar , lift , mounts
Daystar 1" body lift bolts jakeh937 Chassis and Body 15 07-12-2018 07:59 PM
Daystar replacement body mounts billyballer Chassis and Body 4 04-16-2014 03:09 AM
Daystar 1" Body Lift gopbobby Chassis and Body 4 10-06-2012 12:47 AM
1inch body lift on 4inch suspension lift? Thoughts and issues. Austin Suspension and Steering 9 07-17-2012 08:32 PM
