Default Daystar 1" Body Lift
Old 09-27-2012, 11:52 PM   #1
gopbobby is offline
gopbobby
Vehicle(s): 1976 CJ5 sold 1st Jeep, 1982 CJ7 Limited 258-Auto, 1982 CJ-8 Scrambler SL, 1983 CJ7 Renegade Project 1993 4.3L Chevy V-6
Rep Power: 0 gopbobby is on a distinguished road
I bought a new unopened Daystar 1" body lift off ebay. I received it but no hardware with it.
Does anyone know what size/length bolts nuts and washers to use with it?
This is for a 1983 CJ-7.
Thanks,
Bobby
Default Re: Daystar 1" Body Lift
Old 09-28-2012, 09:32 AM   #2
PaRenegade is offline
PaRenegade
PaRenegade's Avatar
Images: 20
Rep Power: 10 PaRenegade is on a distinguished road
Is it the poly body mounts with an additional 1" built in? If so they are all 3/8" bolts but with 3- 7/16" bolts for certain apps. The lengths I'm not sure of. Mine is still in the box, I'm not to that point yet. Check Daystar's site, they may have installation instr. there and I believe it has a list of materials included.
Old 09-28-2012, 07:33 PM   #3
gopbobby is offline
gopbobby
Thanks for the info. It is the poly body mounts with the 1" built in.
I was surprised when I opened the box and no hardware and no instructions. The poly mounts were in a clear plastic bag unopened inside and the box was a Daystar box that appeared to be unopened also.
I guess Daystar sells just the poly mounts, I didn't think to ask the ebay seller if it included hardware. You would think I would learn to not assume by now.
Live and (hopefully) learn I guess.
I will check the Daystar website.
Thanks,
Bobby
Old 09-29-2012, 02:26 AM   #4
PaRenegade
PaRenegade's Avatar
Images: 20
It's probably the same kit I have, which is #KJ04502 for 80-86 cj-5 and cj-7 1" body lift. If so, the bag of bolts your missing also has the washers and the bushings you'll need. It's bag of hardware kit #BU76080. The instructions you'll need is instruction sheet P10422-11
The bolt lengths are 5" for the 3/8"-16's and the 7/16"-14 are 3 1/2"
Old 10-06-2012, 12:47 AM   #5
gopbobby is offline
gopbobby
Exactly the info I needed!
Thanks,
Bobby
body , daystar 1 , lift
1inch body lift on 4inch suspension lift? Thoughts and issues. Austin Suspension and Steering 9 07-17-2012 08:32 PM
Can I see CJ5's with 2 1/2" lift & 32" & 33" tires?? 65reissue Suspension and Steering 6 04-26-2012 09:41 AM
1" body lift rr41mag Chassis and Body 9 10-07-2011 10:22 PM
3" body lift steering adjust toddp Suspension and Steering 6 12-20-2010 08:09 PM
