Chassis and Body Body, Interior, and Electrical, Frame... |
Connecting Fuel filter after fule pumpThis is a discussion on Connecting Fuel filter after fule pump within the Chassis and Body forums, part of the CJ Forums category; Hi all,
Not been on in a while. I put in a new fuel pump and when connecting the stell ...
09-16-2018, 10:03 AM
Vehicle(s): 1994 Jeep YJ,
1982 CJ7 Renegade,
1979 CJ7 Renegade,
1978 CJ7 Golden Eagle
Hi all,
Not been on in a while. I put in a new fuel pump and when connecting the stell fule line back for pump to carb I seem to have a leak at the compression nut. I can;t find a size to fit in any parts store in Ireland.
What is the thread size and nut connector thingy called that I put on the end of the hard fuel line into the top of the fuel pump. Its an 82, cj7 258.
Also if theres a link to one on ebay please post.
Ken
Re: Connecting Fuel filter after fule pump
09-16-2018, 10:30 AM
Vehicle(s): 1979 Jeep CJ7 TH400 Automatic 258 I6 Quadratrac Amc 20 rear & Dana 30 front, 32 x 11.5 x 15 tires. Currently a Complete Custom Rebuild in progress.
Also I own a 2001 Jeep Cherokee, White, all stock with 4.0L. automatic, and police package. Best part of that is it came with leather seats! I use it as my emergency response vehicle for all County emergencies. LED Lightbar installed on top.
It should be just a flared nut. The end of the fuel line is flared to fit over the connector on the fuel pump, A special flare nut is used to hold the tow ends together.
Either this:
Or this:
Hope this helps.
09-16-2018, 03:54 PM
That would be a 5/16" flared nut. Straight lengths are available and you can bend your own as they are of a softer steel.
09-18-2018, 04:22 AM
1982 CJ7 Renegade,
1979 CJ7 Renegade,
Thats great guys thanks for the info. Will order a few to have.
Thread Tools |
Display Modes |
