Default Cluster lights losing ground
Old 07-20-2018, 07:50 PM   #1
Gungho is offline
Gungho
Vehicle(s): '78 cj5 258 straight 6, 3 speed manual, hei distributor, motorcraft 2100 carb with electric choke.
Rep Power: 4 Gungho is on a distinguished road
I replaced the lights in my speedometer cluster because they weren't working. The new bulbs work, but will lose ground when I put them completely in. I know these bulbs get their ground from the "fingers' touching the speedometer housing. They work if I don't push them all the way in, but then they fall out when I drive. Any ideas on how to fix this grounding issue?
Default Re: Cluster lights losing ground
Old 07-20-2018, 08:40 PM   #2
oldjeeplady is offline
oldjeeplady
Vehicle(s): 1979 CJ7 V8 304 T18 w/gran low D20 w/TeraLowD30 D44, 1959 CJ5 Rebuild 74 Buick 231V6 oddfire T14 D20 D30 D44 frame boxed roller engine ready, 1967 CJ5 V6 225 T86aa D18 D27 D44 runs needs work, 1954 CJ3B F4-134 T90A D18 D25 D44 Half Cab needs tub, 2000 Ford Explorer XLT V6 all stock with CO wheeling exp
oldjeeplady's Avatar
Images: 45
Rep Power: 10 oldjeeplady is on a distinguished road
Are the "fingers" on the bulb housing clean? Do you have a dedicated ground run to the cluster gauge? Is the area where the bulbs plug into free of corrosion or rust? These are things I have found to be a problem with those lights. Hope that helps!
Sent from my living room using Tapatalk
oldjeeplady (lady jeeper extremely fond of old CJ's)
cluster , ground , lights , losing
Brake lights turn on front signal lights? richs66chevelle Chassis and Body 12 12-14-2017 02:36 PM
Instrument Cluster Lights not working! jzak Chassis and Body 9 03-29-2014 08:45 PM
Losing my shop and rambling. mylittlecj5 Misc CJ Discussion 14 08-29-2012 10:34 PM
86 CJ7 Losing power jeepjunkie Drivetrain 6 12-29-2010 10:22 PM
Can't Win For Losing: Chrysler kills Cash for Clunkers incentives after running out o Im Not Spam Jeep News and RSS feeds. 0 08-03-2009 09:57 AM
