Default Cj7 vs yj hardtop
Old 12-04-2015, 03:08 PM   #1
Az84cj7 is offline
Az84cj7
Vehicle(s): 84 cj7 Inline 6, mopar fuel injection , T5 trans, dana 300, Dana 44's
Az84cj7's Avatar
Rep Power: 11 Az84cj7 is on a distinguished road
So I understand that a yj hardtop will fit a cj7. My question is where the hatch from a yj hardtop meets the cj7 tailgate when both are closed is there any sort of gap? Are there any other concerns? If u have any pictures please share.
Thx
Default Re: Cj7 vs yj hardtop
Old 12-04-2015, 05:24 PM   #2
Morris4x4Center is offline
Morris4x4Center
www.jeep4x4center.com
Vehicle(s): CJ 8 Scrambler CJ 7
Rep Power: 8 Morris4x4Center is on a distinguished road
Thx
Just passing through and thought this thread might help you!
http://www.jeep-cj.com/forums/f99/di...-hardtop-3539/
-Chris
Email Our Sales Team:
[email protected]
The Following User Says Thank You to Morris4x4Center For This Useful Post:
LIVELY5R (12-04-2015)
Old 12-05-2015, 10:01 AM   #3
Az84cj7 is offline
Az84cj7
Az84cj7's Avatar
-Chris
Thanks for the sticky Chris. I actually have read that already. It doesn't quit give me the info I'm looking for. I'm Trying to figure out if there is a gap between the yj hardtop and the tailgate of a cj7 when both are closed? Also if there is any sort of issues to be concerned about when using a yj top on a cj7?
Ooorrr if someone has some pictures of this setup.
Thx
Old 12-06-2015, 09:24 PM   #4
elwood blues is offline
elwood blues
Images: 58
Rep Power: 15 elwood blues is on a distinguished road
When I wrote that sticky thread I never found anyone that had a YJ top on a CJ7, or a CJ7 top on a YJ. There's lots of threads on other forums where other people talk a lot about it, but no pictures or detailed write-ups.
From what I read, the fitment isn't the problem. It's the order in which the 2 different tops and tailgates are supposed to close that's the problem. Everything I read said that a CJ7 top on a YJ will have to have some of the fiberglass trimmed from the bottom of the hatch for it to seal and close tightly, plus getting rid of the lock mechanism stuff. And a YJ top on a CJ7 requires coordination to close go the the tailgate and the top' s hatch at the same time, so that the weatherstrip thing seals against the tailgate correctly.
Old 12-08-2015, 09:57 AM   #5
Az84cj7 is offline
Az84cj7
Az84cj7's Avatar
Ok yep I got it now. So yj top will work but not ideal. Seems in order to close the rear tailgate on the CJ the hatch from the yj top needs to be closed first. Now this would be tricky because of the way the cj's tailgate latch mechanism locks from the inside. Would be kind of hard to do this with the glass hatch shut. No way to reach in from the rear.
My next question is will the full yj doors work with the cj7 hard top. I know hindge fitment and latch are correct but when closed do they fit the contour of the yj top and close flush?
Old 12-08-2015, 11:32 AM   #6
gr8dain is offline
gr8dain
Vehicle(s): '84 CJ-8
Rep Power: 11 gr8dain is on a distinguished road
Yes. The YJ full doors work with the CJ8 half cab I have so I would assume they would work on a CJ7 top as well.
Old 12-08-2015, 11:50 AM   #7
elwood blues
Images: 58
cj7 , hardtop
Hardtop-Mod jbdoom87 Chassis and Body 11 04-21-2014 11:14 AM
Will this hardtop fit my 79 CJ5? Rexx66 Chassis and Body 3 12-16-2013 04:24 PM
YJ hardtop? FishinMagician Chassis and Body 4 02-27-2012 09:35 PM
Hardtop needs some TLC.. Project86 Chassis and Body 2 05-22-2011 01:03 PM
hardtop for a 78 cj5 ga78cj5 Chassis and Body 2 02-15-2011 04:45 PM
