Default CJ-8 Frame - Patch or Kit?
Old 03-04-2018, 09:06 PM   #1
CJ8Palmer is offline
CJ8Palmer
Vehicle(s): '46 CJ2, '77 CJ5, '84 CJ-8
Images: 2
Rep Power: 0 CJ8Palmer is on a distinguished road
My wife and I have a '84 CJ-8. Body is fiberglass and in good shape, but frame behind rear wheels is bad. Are there good patch kits for this or can a good welder simply piece-part patches to fix? Attached are some shots.
Default Re: CJ-8 Frame - Patch or Kit?
Old 03-05-2018, 08:50 AM   #2
Caleb7mm is offline
Caleb7mm
Vehicle(s): 85 CJ7 4.2, t-5, twin sticked D300, flat fenders, spartan locker and revolution 1 piece axled amc20, 1 ton flipped over knuckle steering d30 with spartan locker, 4 suspension lift, 3 body lift, 35 Dunlop mud terrains, smittybuilt winch, warn winch plate, stubby front bumper, heavy duty rear bumper.
Rep Power: 0 Caleb7mm is on a distinguished road
Find a reputable welder. Easy fix
Old 03-05-2018, 12:07 PM   #3
Sandblast the area and then do the hammer check.
Old 03-05-2018, 10:39 PM   #4
CJ8Palmer
Images: 2
Thanks for the advice - I'll give it a try!
Old 03-10-2018, 10:41 PM   #5
BIG4D is offline
BIG4D
Vehicle(s): 1983 CJ7, hard top & doors. 3 in BDS suspension lift. Stock 4.2 I6 Trans: T4, 4 spd Xfer: Dana 300 Front Dif: Stock Dana (I believe) Rear Dif: Stock AMC
Images: 8
Rep Power: 3 BIG4D is on a distinguished road
I just installed the auto rust.com repair kit on my 83 CJ. Same problem. Great kit, great product, perfect repair.
The repair pieces come with the welded nuts for the rear spring shackle mounts. Get you tape measure out and get yourself a good welder (equipment and person) to weld it up for you. Mine was REALLY bad and there was not a lot of the frame left back there. Still worked perfectly!
Here are some before and after pics.
Old 03-10-2018, 10:49 PM   #6
Rep Power: 23 Petescj is on a distinguished road
Just remember if you get a prefab kit to fix it it has to be Cj-8 specific. The rear frame area of a Scrambler is quite different than a Cj-7
Old 03-11-2018, 08:46 AM   #7
CJ8Palmer
Images: 2
Great! this shows the body off the frame though - can kits be installed with body on the frame?
Old 04-16-2018, 11:33 PM   #8
BIG4D is offline
BIG4D
Images: 8
Yes. Many people have installed them with the body on. Just remove the rear most body mount. Actually, remove the bolts from all but the mount under the radiator and jack the body up a couple of inches. Block it up with a couple pieces of wood to give yourself more room to work. Plan on replacing the rear crossmember. They are not expensive and you will end up cutting your original up to get the frame pieces out and back in.
The Following User Says Thank You to BIG4D For This Useful Post:
Torxhead (04-18-2018)
cj-8 , frame , kit , patch
Quarter Panel Patch question. Icon Chassis and Body 2 11-21-2014 01:26 PM
Cowl/ under Windshield patch mattmont Chassis and Body 1 11-16-2013 02:54 PM
Cj7 frame patch Midlife Chassis and Body 5 03-28-2013 08:39 AM
Frame Repair - Patch Welding? coffman Chassis and Body 3 02-28-2011 10:01 PM
Tub Patch JEBETS Chassis and Body 4 10-26-2010 09:40 AM
