Default brake booster on a YJ tub sitting on a CJ frame
Old 10-29-2019, 08:55 AM   #1
bbbobbb is offline
bbbobbb
Vehicle(s): 1984 CJ7 258, Dana 30 & 44,
Rep Power: 0 bbbobbb is on a distinguished road
Hi Jeepers,
Im trying to figure out what correct filament I should use to get the correct power Booster/Master cylinder on a 84 CJ7 frame with a YJ tub, Will I also have to get a different manifold brake thingie also ? (not sure what its called)
Default Re: brake booster on a YJ tub sitting on a CJ frame
Old 10-29-2019, 09:57 AM   #2
Pretty sure you can just use the stock Cj booster and master cylinder. The thread below will show you booster. That's what's on mine with a Yj tub. Last page on the thread below will show you a pic. You'll have to click the link to open it though.
https://www.jeep-cj.com/forums/f98/v...cj7-29377-new/
Old 10-29-2019, 09:59 AM   #3
I used all stock CJ stuff, you definitely want to get rid of the YJ brake pedal I found the hole was in the wrong place for my CJ brake linkage
Old 10-29-2019, 10:59 AM   #4
Manic Mechanic is offline
Manic Mechanic
Manic Mechanic's Avatar
Images: 11
I just used all yj parts easier to get plus my CJ was a none power break
Old 10-29-2019, 02:35 PM   #5
Did you have the YJ proportioning valve? I believe that's another piece that would need to be swapped as well. Definitely if your going from non power to power brakes.
Old 10-29-2019, 02:37 PM   #6
Manic Mechanic
Images: 11
CJ valve that doesn't make a difference with power and non power only with disc and drum
The Following User Says Thank You to Manic Mechanic For This Useful Post:
Petescj (10-29-2019)
Old 10-29-2019, 02:56 PM   #7
Yup you got me. Thanks for the clarification
Old 10-29-2019, 03:29 PM   #8
Manic Mechanic
Images: 11
I'm going to be changing to 4 wheel disc at that point I will change the valve
booster , brake , frame , power brake booster , sitting , tub
Bad brake booster? thescot Suspension and Steering 1 08-24-2013 10:07 AM
Brake Booster dalenelson Suspension and Steering 4 05-11-2011 12:44 AM
brake booster jamie Suspension and Steering 5 10-17-2010 09:28 AM
Brake booster lmk3087 Drivetrain 8 05-26-2010 11:23 PM
yj brake booster 79Jeep5 Misc CJ Discussion 1 09-24-2009 04:47 AM
