Default Body mount kit question
Old 01-14-2020, 12:08 PM   #1
Scout1067 is offline
Scout1067
Scout1067's Avatar
Images: 3
I am going to pull the tub on my CJ this spring to repaint it and treat the frame. Since I am going to pull it anyway I figure I should replace the body mount bushings while I am at it. I am looking at the Energy Suspension Body Mount Bushings from Summit: https://www.summitracing.com/int/par...jeep/model/cj7
My question is do I need to order spacers for the bushings as well or do I just need the bushings and new bolts? Looking in the parts manual all the bolts i see are 2 1/2" I would assume they are 1/2" in bolts as well from looking underneath. Even better does someone have a parts list from their build that they can point me to and I can pull the list off myself?
Default Re: Body mount kit question
Old 01-14-2020, 01:59 PM   #2
Sbasham1 is offline
Sbasham1
Vehicle(s): '85 CJ7, 258 AMC, T-176, ??, Dana ??, 32x15 mud tires
Rep Power: 0 Sbasham1 is on a distinguished road
I took my tub off on Saturday from my '85 CJ7 that has spent its entire life in Florida with minimal rust. 8 of the 10 bolts were all entirely destroyed on removal due to decay. Additionally the front 2 were not the same length as the rear 8. The metal inserts into the bushings are/were dust.
Only other rust I've found on the entire car is where the roll bar was mounted. I'd expect to be replacing everything on your application when you get it off if you're in any similar of a boat to me. I'm getting the entire bushing kit from day star, and sourcing out my bolts/washers from a local hardware store with grade 8 bolts.
The Following User Says Thank You to Sbasham1 For This Useful Post:
Scout1067 (01-14-2020)
Old 01-14-2020, 02:35 PM   #3
Scout1067
Scout1067's Avatar
Images: 3
I live in Germany with all that entails with road salt. What I find odd is the only kits I can find that have the sleeves are from crown and omix, which I would prefer to avoid if possible.
Sent from my SM-A405FN using Tapatalk
Old 01-15-2020, 11:30 AM   #4
Patrick is offline
Patrick
Patrick's Avatar
Stainless steel hardware with a dab of anti seize compound is ideal here. Using the button head bolts on the roll bar adds a nice touch. This option is more expensive, though.
CJs are not getting older, they are getting faster!!!
Old 01-15-2020, 01:45 PM   #5
Scout1067
Scout1067's Avatar
Images: 3
I have decided to go with stainless steel, found the sizes I need in grade 8 on McMaster-Carr. I am going with hex head though as I have had enough fun with button head bolts to last a lifetime
body , kit , mount , question
Body Mount Question JeepCJ5 Chassis and Body 16 12-22-2016 08:18 PM
Body mount question w/pictures Colo Dean Chassis and Body 1 08-31-2014 02:32 PM
Body mount question nickgodwin1 Chassis and Body 3 03-17-2011 10:39 PM
body mount question? myfirstcj Chassis and Body 7 02-08-2011 07:48 AM
Body Mount Question phinleft Chassis and Body 12 06-23-2010 09:26 AM
