Default Body Mount Bushings
Old 01-01-2020, 07:55 PM   #1
Flundertaker is offline
Flundertaker
Vehicle(s): '80 CJ7, 258, T176, D300, D30, AMC20 Pretty Much Stock . . Gone but not Forgotten: '76 CJ7, 360, NP435, D20, D60, D70 42" TSL
Rep Power: 0 Flundertaker is on a distinguished road
Several of my body mount bushings are split and falling apart. What brand replacement is recommended and is there a reasonably simple way to replace them without pulling the tub off? I donít want what should be an easy job to turn into a project that has my Jeep in parts for the next year or more.
Default Re: Body Mount Bushings
Old 01-02-2020, 09:02 AM   #2
TnCJ is offline
TnCJ
TnCJ's Avatar
Rep Power: 1 TnCJ is on a distinguished road
I used Day Star polyurethane bushings. [one inch lift]
You don't have to take the body off, just loosen all of the old mounts [good luck with that] remove them one at a time, put a jack under one side of the body closest to the one you are removing and slip a new bushing in between body and frame.
Be aware that you will probably find most of the bolts rusted and frozen into the captured nuts. Some can be accessed fairly easy some are impossible. I had to cut a hole to get to one of mine.
Start applying liberal amounts of PB Blaster several days ahead of time.
I like the Daystar bushings, they shorted me several of the large washers but were very prompt in sending me new ones.
Old 01-02-2020, 09:34 AM   #3
j6824 is offline
j6824
Vehicle(s): '78 CJ5, 258, D30, AMC 20, 3.54, T150, 33s, Gronk MC2100, 4"BDS, 1" M.O.R.E. body, Team Rush, MDS 6A, BDO tie rod flip, Adams shafts, Speedhut gauges, 8274
j6824's Avatar
Rep Power: 4 j6824 is on a distinguished road
I went with the Mores
https://mountainoffroad.com/collecti...-80-86-cj5-cj7
Like TN, I went with the extra inch. If you loose everything all the way around first you can jack the tub up enough to get 'em in
Had a couple of the captured nuts that wouldn't let go...even after a steady diet of PB over several days. Luckily they were where I could get to them after a little cutoff wheel work
Could have been a lot worse...those things are hateful
body , bushings , mount
Replacing body mount bushings tireman74 Chassis and Body 32 08-24-2014 12:00 AM
Who has correct body mount bushings. aceves6 Chassis and Body 2 05-20-2014 11:21 AM
advice on worn body bushings rockinreel Chassis and Body 9 05-22-2013 11:30 PM
Body Mount Bushings 1moreshot Chassis and Body 6 10-03-2012 06:38 AM
Body bushings - fiber tub install cwiehle0 Chassis and Body 5 12-05-2011 10:16 AM
