Default Body bushings - fiber tub install
Old 12-02-2011, 09:44 AM   #1
cwiehle0 is offline
cwiehle0
Vehicle(s): 86 CJ7 07 Commander, 06 Mazda
cwiehle0's Avatar
Rep Power: 0 cwiehle0 is on a distinguished road
Morning guys,
I tried a search on this with no luck. I'm installing a 4wd hdw tub on my 86 CJ and have some questions for you all if anyone can help. I posted a rudimentery drawing below but it keeps loading real small. I numbered the body mounts 1-4 starting front to rear respectively.
Assuming the frame has no rake built in at the factory, I leveled it the best I could for now. I am also going to assume for now, unless someone tells me otherwise that the body should be level to the frame.
The #4 mount was the shortest bushing size so I started there with 1.5" spacers. to get the body level I had to put approx. 1.5" spacers in the #1 position. With the body now fairly level I measured the #2 mount gap needing approx a 2.5" bushing and the #3 mount needing approx a 2.25" bushing.
Do these measurements sound good to you guys. I have the 2' long length of rubber and want to get some opinions before I start cutting. I was going to lift the body a 1/2 " or so over stock height, but it already seems fairly high with needing that 2.5" bushing in the #2 position.
Any and all advice on this will be well appreciated.
If anything needs clarification let me know.
Thanks Chris
Default Re: Body bushings - fiber tub install
Old 12-02-2011, 09:44 PM   #2
johnbilt is offline
johnbilt
Vehicle(s): 1973 CJ5 - AMC360 /EB Performer intake / Isky Cam / Holley Carb - T18 - D20 w/2.41 Low - 4.56 Locker Rear and Front Pwr-Lok.
Rep Power: 9 johnbilt is on a distinguished road
I have a 73 and a 76 CJ. Not sure how this is different from the 86. I can tell you this. Getting the body and frame to fit perfectly is a headache. I'm not sure how you are levelling the setup, but here are a few suggestions.
1) Get frame as level as possible left to right. I think I put a jack stand under the frame to get the springs out of the equation. Then I adjusted the stands and shimmed to make this happen. I also set the frame mounts up so the tub would sit level front to rear. This is trickier because the bottom of the tub has some angles built into it. I think I levelled the center of the frame where the front floor sits.
2) Then set the tub on top and bolt it down maintaining a level body. The fiberglass may have some variations, but shimming should get this straight. The front mounts (#1 in the front) generally have a taller mount than the others. This is certainly true on my 73. Not sure on your year.
Hope this helps.
Old 12-02-2011, 09:52 PM   #3
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
Rep Power: 13 73CJ is on a distinguished road
You're on the right track.
Level the frame, put the tub on and make sure it's level. You never know what the tub may have. Some are better than others but can vary a lot.
Then using the hood and grill, making sure it's also level, figure out the height needed.
Old 12-02-2011, 09:53 PM   #4
73CJ is offline
73CJ
73CJ's Avatar
Images: 61
Jonbuilt you type faster than I.
Old 12-03-2011, 04:37 PM   #5
johnbilt is offline
johnbilt
I manage to fat finger my words in. I hope our fellow jeeper can make some progress getting his machine back together. Cheers.
Old 12-05-2011, 10:16 AM   #6
cwiehle0 is offline
cwiehle0
cwiehle0's Avatar
Thanks guys, I didn't have any time over the weekend to work on the jeep. I'll keep you posted.
body , bushings , fiber , install , tub
Swaybar bushings jr86CJ7 Chassis and Body 5 03-29-2018 01:30 AM
Body Mount Bushings 1moreshot Chassis and Body 6 10-03-2012 06:38 AM
74 CJ 5-Winch install, Front Bumper Install es335 Chassis and Body 10 09-01-2012 11:46 PM
Bushings driver007 Suspension and Steering 2 10-26-2011 09:36 PM
Install body panels? jeepmedic Chassis and Body 12 01-15-2011 12:17 AM
